Old 06-15-2019, 01:50 PM   #1
oreddie
OREddie's Avatar
Erratic Transmission - No Warning Lights
Day 5 of trip across southern Canada in 2017 2401WS. Leaving campground at slow speeds (under 20) and in Drive, transmission started shifting up and down, sometimes almost redlining RPM, then back up with a rather firm shift.
No place to stop so I played with manual shifting with some success. Managed to get 80 miles at mostly highway speeds. When I slowed to enter a parking lot the issued recurred.
No warning lights. Any thoughts?
Ed
oreddie
'17 Forester 2401WS
OREddie is offline   Reply With Quote
Old 06-15-2019, 02:16 PM   #2
rsdata's Avatar
OOPS...
should have known these new trannys do not have dipsticks... like my 2014 RAM...
ignore the lines I originally wrote at bottom...
anybody else see all of this tech in new vehicles as a way to get dealer repair operations profitable as so little can be done by the owner anymore?
with engine warm and running and tranny in neutral, check the fluid level. transmission fluid should be a brite red transparent color... the closer to brown it gets means it needs to be changed...
ďToo much of anything is bad, but too much good whiskey is barely enough.Ē Ė Mark Twain
2014 Shamrock 183
Old 06-15-2019, 03:35 PM   #3
Rich.M's Avatar
Surprising that the check engine light or other warnings did not come on. There are so many sensors on various systems in these vehicles. The obvious question is to check the transmission fluid level. The sprinters donít come with trans dipsticks. You have to own the dipstick and replacement locking tabs ( one use only) for the dipstick port just under the radiator overflow. You can order these on amazon but that wonít help you on the road. Is there any sign of losing trans fluid?. The plastic 13 pin connector at the corner ( donít remember which corner) above the pan can fail and leak . Thatís a cheap fix, solenoids and conductor plates can fail and be replaced. After that itís hard to know. Head for a Mercedes dealer. At least they can check the fluids on the sealed transmission and maybe pull codes if not a sprinter center. Good luck.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 06-15-2019, 03:44 PM   #4
Rich.M's Avatar
Here are links to the dipstick I described for those following
https://www.amazon.com/ATLIN-Mercede...SIN=B075SVZB4B
These are the replacement locking tabs, I have used them without problems
https://www.amazon.com/Dorman-917-29...YSTAE20NWMTS4W
2015 Solera 24r
2017 Jeep Wrangler
Old 06-15-2019, 03:50 PM   #5
oreddie
OREddie's Avatar
Tow time
Shame on me. I didn't know how to check transmission fluid and don't have replacement parts. MB serviced 2800 miles ago.
We managed to get to Lethbridge, Alberta and parked safely. When I restarted I could get into reverse and neutral but engine shut down as soon as I went in to Drive, kinda like a stall with a manual transmission.
We're resigned to staying here at least until Monday. Could be worse tho.
Thanks for the ideas.
Old 06-15-2019, 03:51 PM   #6
oreddie
OREddie's Avatar
Thanks. I'll order them tonight.
oreddie
'17 Forester 2401WS
Old 06-15-2019, 06:27 PM   #7
Rich.M's Avatar
My suggestion was for erratic shifting but if your stuck then call Mercedes roadside assistance. Your are probably still under warranty with a 2017 . I think they pay for towing to an authorized Sprinter service if it is a warranty problem causing you to get stuck. Good luck, sorry about your disrupted travel plans.
2015 Solera 24r
2017 Jeep Wrangler
Old 06-15-2019, 09:00 PM   #8
chroniekon's Avatar
I noticed a small leak (just a few drops) on a crossmember towards the front of the transmission a few months ago when I was under there changing the engine oil. I took it to the dealer and they found a bad oil cooler fitting. They said it was only the second one they had seen, both on motorhomes. All repaired under warranty.
Have you tried crawling around underneath to see if anything obvious is amiss? An electrical connector knocked loose, maybe some scuffed wires, some damage from some flying debris, a vacuum hose pulled loose. If it's low on oil, I would think there would be a noticeable mess under there.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 06-16-2019, 05:16 AM   #9
This sounds a lot like a Wheel sencor problem. You should have warning lights on dash. Mine acted same way and then straighten itself out for a while. Iíve replaced 3 on my 2025 Solera. Good luck hope itís a simple fix.
lwalkplumb is offline   Reply With Quote
Old 06-16-2019, 03:28 PM   #10
oreddie
OREddie's Avatar
Thanks all. Tow truck driver took a close look and didn’t see anything amiss while he was disconnecting the drive shaft. MB paid for 140 mile tow to Calgary.
My son, an MB tech in the Bay Area, talked to his Sprinter crew - they suspect a faulty transmission valve body. He also suggested removing engine battery negative terminal the reattaching after 10 minutes to reset computer. We were already under tow by then tho.
We’ll hopefully know sometime tomorrow.
oreddie
'17 Forester 2401WS
light
