Originally Posted by Beachsailor
I swapped out a vent and also found styrofoam with channels for ac air flow in the ceiling. That's why I was surprised to not find it in the wall.
If your talking about the walls exposed to weather, you should have styrofoam, they are pressed together as one section, now any wall that is interior like the bathroom interior walls then no. There are some exceptions. behind my shower surround on the outside wall there is a channel that has not been insulated do to that is where they ran water lines and my black tank anti back flow valve is located in that area. Also there is zip insulation under my front cap.....
