Old 06-10-2016, 09:51 AM   #1
hkreck's Avatar
EZ oil drain valve
For those of us that change their own oil, I was wondering if anyone has used the EZ oil drain plug? I first saw it last year in motorhome magazine and was thinking of getting one before my next oil change but wanted to look at some input first. The cost is last than $30 for the plug and it looks easy to use and install, What do you think?
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is online now   Reply With Quote
Old 06-10-2016, 10:01 AM   #2
Have used them on both of my motorhomes. Never a problem and a really simple way to change oil.
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 06-10-2016, 10:24 AM   #3
Campster's Avatar
I use one on my Dodge Ram diesel, makes for a real nice and easy oil change. This engine holds a lot of oil, the first time removing the drain plug it gushed out of there and made quite a mess. That no longer is a problem.
Campster is offline   Reply With Quote
Old 06-10-2016, 10:29 AM   #4
I use a similar valve on all of my vehicles including race cars. I suggest taking a look at the Fumoto brand - the original designer of the valve.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3.73 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2016: 38 nights camped
Teamfour is offline   Reply With Quote
Old 06-10-2016, 10:32 AM   #5
SeaDog's Avatar
I use the Fumoto quick valve. It has a very positive locking spring. Sure makes changing the 15 quarts in the 6.0 a breeze I also have one in each cooling drain
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 06-10-2016, 10:33 AM   #6
Who Dares, Wins
doc73's Avatar
I have used both the EZ Oil and the Fumoto. Currently using the Fumoto. Both were great for making the changes painless and clean. Never had any leaks or issues.
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 06-10-2016, 10:36 AM   #7
Campster's Avatar
Fumoto is the brand I am using too... Never have had any trouble with it.
Old 06-10-2016, 11:06 AM   #8
bubbles's Avatar
I use the Fumoto with the nipple to attach a drain hose to bypass a chassis cross member. Without it the oil drains directly onto the cross member. Makes for a no mess drain.
Old 06-10-2016, 11:18 AM   #9
waiter21's Avatar
I changed the oil about a month ago and installed a Fumoto valve then
I bought the snap on nipple thing and put a 2 ft piece of hose on it.
Next oil change should be a little cleaner and easier: Snap the hose onto the valve, open the valve, and come back in 20 minutes.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-10-2016, 11:39 AM   #10
hkreck's Avatar
Thanks for the input guys, after looking I went with the Fumoto also, was able to get the kit with hose, safety clip and everything needed. Also got 10% discount for father's day.
Henry & Tena
2013 Solera 24S
The Great Escape
drain
