Old 09-27-2017, 07:47 PM   #1
Fan running beside the fuse box that is above the refrigerator.
We are new to this and we have only had the RV 6 weeks. I have never heard the fan running that is located above the refrigerator and beside the fuse panel. We turned our LP gas off a couple of weeks ago when we put the RV in storage. We got the RV out to get ready to go on a short trip. We plugged into electric and the fan started running. Can't recall that ever happening. Just wondering what triggers that fan to run and why did it just start? Should it run all the time? We are a bit scared to leave it plugged in all night as we are not sure why it just started running. Thanks in advance!
sunseeker56 is offline   Reply With Quote
Old 09-27-2017, 08:01 PM   #2
herbike's Avatar
Could be your converter, most have a cooling fan and if you had let your TT set long enough the batteries were low. It could be that the converter got warm enough to kick on it's cooling fan. If that's where your converter is located next to your fuse panel.
Would be best to leave it plugged in all night to charge the batteries up before you leave camping.
We love camping in our Shockwave!
2016 t28FQDX Shockwave,
New Provider tires 10/31/18 ,
2021 Chev LT 3500
2020 Polaris RZR 900 Fox Edition
herbike is offline   Reply With Quote
Old 09-27-2017, 08:20 PM   #3
You don't say which Sprinter floor plan you have, but it sounds like the converter is charging your batteries (converters are in differing locations, depending on the model). This is normal. Leave it plugged in. However, do make sure when you store it, even for a short time, to turn OFF the main power switch, which should be located in the entry stairwell at the battery control center.
Mark & Susan
Former MBS 24R and 2401W Owners
Just recalibrating our camping set-up for now!
barnbnb is offline   Reply With Quote
Old 09-27-2017, 08:24 PM   #4
Our converter fan will spin up if the battery is low. In many RVs the smoke detector is hard wired to the battery and so is a constant drain. Also, batteries will self discharge over time. Even if you have a battery disconnect switch, check to see if the (and perhaps rewire) smoke detector is indeed connected directly to power.
pjnlorrie is offline   Reply With Quote
Old 09-27-2017, 08:29 PM   #5
Oh, thanks!!! Did not know we had anything else to turn off! Thanks!
Old 09-27-2017, 08:30 PM   #6
Thanks! Will look into that!!
Old 09-27-2017, 08:34 PM   #7
Thanks! We just went out and checked it again and it isn't running as loudly as it first did when we plugged RV into power. Also, just read another post that we should turn the main battery power off which we did not know. Wish there were a step by step, shut down manual on these units.
Old 09-27-2017, 10:19 PM   #8
bikendan's Avatar
A good dealer would have gone over this with you, during the PDI.
Old 09-29-2017, 07:37 AM   #9
droadrunner's Avatar
Dynamax Rev house batteries won't charge with main power switch turned off.
On my 17 Dynamax Rev, the coach power switch must be left ON for the house batteries to charge or be maintained while plugged into AC. Not sure why I would want to turn the main power switch off during storage while plugged into AC since there will continue to be a slow battery discharge occurring.
droadrunner is offline   Reply With Quote
Old 09-29-2017, 07:43 AM   #10
Sorry I misread the original post. Definitely turn OFF main power when not connected to AC during storage!
Old 09-29-2017, 11:39 AM   #11
Be advised, there will still be a parasitic drain in the system even with the switch off. My multimeter reads a draw of .4 amps with the switch off. This is normal, at least I am told that is the case. For long term storage it's best to unhook the batteries under the entry steps or to install a quick disconnect. Your chassis battery will also have a parasitic draw.
Mark & Susan
Old 09-29-2017, 12:27 PM   #12
Converter fans will run at different speeds depending on the load from the converter. High demand...fan will run faster, Low demand...fan will run slow or off.
TheWolfPaq82 is offline   Reply With Quote
Old 09-30-2017, 04:30 AM   #13
Thanks!!
Old 09-30-2017, 04:31 AM   #14
Ok, thanks! Good advice!
Old 09-30-2017, 04:33 AM   #15
Thanks!
fan, fuse, refrigerator
