Old 04-11-2019, 04:14 PM   #1
Forester MBS 2401w Tail light replacement
Although I don't now have access to my rv, I am told the passenger seat tail light is out. The person told me itís a "sealed LED light" and they would have to order a new one from Forest River and replace.
Really? The tail lights on a 2401w are proprietary, not an "off the shelf" item?
rshellhammer is offline   Reply With Quote
Old 04-11-2019, 05:11 PM   #2
Mikegjax's Avatar
I ordered one online some time ago. Took the manufacturer of the light . Easy to find. Also do a search for RV tail lights. Not proprietary at all
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 04-11-2019, 05:15 PM   #3
Mikegjax's Avatar
You might want to check that you have power to the inoperable light assembly.
2014 Solera 24R
USN Retired
Old 04-13-2019, 07:56 AM   #4
Loefflerh's Avatar
https://www.etrailer.com/Trailer-Lig...28-003-85.html
That is the one on my 2017......
23$
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - ?
Loefflerh is offline   Reply With Quote
Old 04-13-2019, 03:07 PM   #5
tail light replacement
check with manufacturer...can probably get them direct...just call if "Command" brand...worked for me. Just be sure to apply sealer as recommended to keep moisture out...that was the reason for the failure of mine.
2015 Forester 2401RSD-MBS
llscott is offline   Reply With Quote
Old 04-16-2019, 07:44 PM   #6
Replaced last week with a command light assembly. Ordered directly from Command website. Sealed both lights with RTV,and sealed the center light lens as well with silicone grease on its gasket.
fishheads is offline   Reply With Quote
Old 04-23-2019, 09:18 AM   #7
Egalt's Avatar
Although I don't now have access to my rv, I am told the passenger seat tail light is out. The person told me it’s a "sealed LED light" and they would have to order a new one from Forest River and replace.
I assume you mean the one on the right. It's LED - doubt it's "burnt out"
Egalt is offline   Reply With Quote
Old 04-23-2019, 06:37 PM   #8
Oh. Did he say passenger seat? No, I think he meant driver's seat. They're backwards when you're facing forwards. Or something.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 04-24-2019, 02:08 AM   #9
namusmc's Avatar
Dave
Dave, you're getting me more confused than a cow standing on Astroturf.
namusmc is offline   Reply With Quote
Old 04-24-2019, 07:24 AM   #10
Egalt's Avatar
I think you have a bigger problem, as the taillights should not be on the seats, they should be on the back of the rig!
Unless you meant passenger "side"
forester, light, replacement
