Old 11-30-2015, 08:02 PM   #21
BendOrLarry's Avatar
Originally Posted by dogpa View Post
I am in Bend and had a run of zero or below for three or four days. I have been using space heaters and no light bulbs. Water froze two nights in a row. I have a 24 R and have put a drop light with a 75 watt in the pump area. Time will tell. Also found at an RV place here a dual valve to install on unit tank that will allow access to both an extra tank for unit and a hose for BBQ.
Last new years eve we were at the new Kapka snow park and it was 12 below zero. We ran the Champion invertor generator all night with two 60 watt bulbs in the pump and tank area, and never froze up. Kept the furnace going all night as well.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 12-24-2015, 06:38 AM   #22
Do you have a photo of how you placed the bulbs?
2016 Sunseeker MBS 2400R + Diesel Gen
2014 Honda CRV
Blue Ox Flat Tow Equipment
SMI Stay-In-Play Brake Controller
ericlakin is offline   Reply With Quote
Old 12-24-2015, 09:16 AM   #23
Sorry no. The coach is under a cover with 2 feet of snow on top. I will get you a picture when we get a break in the snow so we can take the coach on a snowmobile trip.
Firestone airbags
Old 12-24-2015, 10:19 AM   #24
I just hung a drop light inside the door where the pump is and it worked fine. Used a REAL 75 watt incandescent one and it works great.
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 12-24-2015, 11:34 AM   #25
I used two residential light bulb bases mounted close to the water tank and pump. I have a heat lamp in one and a 60 watt bulb in the other. Just be sure the bulbs don't touch anything. I also put a thermometer probe in there so I can remotely monitor the temp with out having to lift the bed.
Firestone airbags
Old 12-24-2015, 11:59 AM   #26
2015 Solera 2400R
We were in NM this last month. Temps down in the single digits. Instead of using the plumbing, we kept 6-8 gallons of water in jugs in the shower. Used RV antifreeze to flush the toilet. Worked well. Made us really think about our water usage.
Echoman is offline   Reply With Quote
Old 12-24-2015, 02:08 PM   #27
As US standards haven't switched over yet I always use F for temps. It was really cold. The door that I accessed to force heat in is inside the rear storage area on the driver side. Light bulb not a bad idea though. Thanks for that. I don't see any exposed water lines under coach except a feeder to black tank for flushing.
Thank goodness we won't be switching to C. Besides, it just feels warmer at 32 than 0.
