Old 09-05-2017, 05:05 PM   #1
Frig Propane Concern
During our last trip, when the propane would ignite for the reefer, it would make make a lot of sputtering and stuttering noises and then burn as it normally does. I also encountered several times where, with stovetop running and propane hot water running, the reefer propane would go out and i would have to relight it from the control panel. On warranty repair, the tech said they had to clean the burner and all is well. This unit does not have that many hours on it for prone use ad it seems to me that this got "dirty" far too soon. I rarely had this issue on other RV's I have owned and am not sure if I am getting the run around on this or not.
2019 Tiffen Allegro Open Road 32SA
F53 / 24000# Chassis
2008 Jeep JKS
Ready Brute Elite / Blue Ox BP
High Desert is online now   Reply With Quote
Old 09-06-2017, 06:17 AM   #2
Some propane burns cleaner , some stinks.
By cleaning and adjusting the air in the fridge burner your problem is probably solved.
IF it returns have a tech observe the pressure with stove m FW heater and fridge on. The regulator may have a problem with low pressure.
FFred is offline   Reply With Quote
propane
