Old 06-05-2019, 04:02 PM   #1
Front steel valve stems
We purchased the tst507 tpms system. Went to My Tire Supply and purchased the fully set of chrome steel stems for the 2015 sprinter. The rear stems are perfect! The front stems barely come out of the hole in the simulator. You see maybe half the thread on the stem so the sensor wont be able to be put on. I called My Tire Supply and they told me I purchased the correct set. The front stems are 2.25 inches long. The only other length they have is 3.5 which is way too long. The only solutions she could give me was to not use the simulators and to cut the hole in the simulator so it would not touch the stem. I can cut the hole but the stem is still too short. I have searched the forums relentlessly to see if anyone else has had this problem. I hate the idea of not using the simulator. Does anyone have a solution or do you know where I can get the stems in the proper length?
Desertsquid is offline   Reply With Quote
Old 06-05-2019, 04:09 PM   #2
If 2.25 is to short then seems 3.5 is all you can do . only talking 3/4" if they are steel i wouldn't think it would be a problem
MR.M is offline   Reply With Quote
Old 06-05-2019, 04:38 PM   #3
wmtire's Avatar
They make clamp-in valve stems of many varying lengths. Your supply place may just not carry them.
Can you post a pic of what you got, or perhaps the manufacturer number from the sales receipt and I'll find you the correct ones to solve your problem?
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 06-05-2019, 04:47 PM   #4
valve stems
The kit I bought was DL1SP13FR225 2.25 with 10-15 degree bend. I appreciate your help
Old 06-06-2019, 10:58 AM   #5
Mikegjax's Avatar
I have 1 3/4 stems installed on the front at the present time with TPS installed on each. I am able to get the sensors on and off without much difficulty. At the next tire change I will install the 2 1/4 stems and bend them slightly to make it a bit easier.
DL1SP13FR Chrome Duallyvalve Kit W/ Front Stems
ID:	206568   Click image for larger version
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 06-06-2019, 11:50 AM   #6
That is the same kit I have. My front stems measure 2.25 just like your bottom picture. The TPMS sensors won't fit even with the holes enlarged.Click image for larger version
Old 06-06-2019, 01:21 PM   #7
Mikegjax's Avatar
That is the same kit I have. My front stems measure 2.25 just like your bottom picture. The TPMS sensors won't fit even with the holes enlarged.Attachment 206572
Strange! Your photo looks to me like the short stems that my sensors are on (my top photo).
2014 Solera 24R
USN Retired
Old 06-06-2019, 04:33 PM   #8
Arithmetic is good
Umm, 3.5 - 2.25 = 1.25. 1-1/4", not 3/4". Arithmetic is good.
Larry
Larry-NC is offline   Reply With Quote
Old 06-06-2019, 05:03 PM   #9
Larry
That's right . well what do you know made a mistake go pat yourself on the back and have a cold one you deserve it after this catch .
Old 06-06-2019, 05:15 PM   #10
Heres a picture of the sensors I have. They're pretty big.Click image for larger version
valve
