Old 12-04-2015, 06:19 PM   #1
MNtraveler's Avatar
Fuses
I was looking to pick up a variety of fuses to have on hand since the MBS has such a huge number of fuses between the chassis and the MH. Per my prior inspection, the MH has fuses that are 5, 7.5, 10, 15, 20, 25, 30, 40, 50, 60, 80, 150 and 300 amps. (Not counting any AC circuit breakers.) So a variety is sure needed on hand!
However, I didn't realize there are not only blade fuses available but also "mini" blade fuses and "maxi" blade fuses, i.e.:
Amazon.com: Tekz 45230 Master Auto Fuse Assortment - 88 Piece: Automotive
And our unit is off at the dealer for a few items of work so I can't go back and look now. Does anyone know if the MBS has mini and maxi fuses or only "normal" blade fuses?? Thanks!
PS:
MNtraveler is offline   Reply With Quote
Old 12-05-2015, 07:03 AM   #2
Mikegjax's Avatar
Does this help?
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 12-05-2015, 07:34 PM   #3
MNtraveler's Avatar
It's a helpful picture but doesn't differentiate between normal sized, mini and maxi. Thanks for posting.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
Old 12-05-2015, 07:59 PM   #4
Mikegjax's Avatar
Standard size; not mini's. Just walked out to mine and checked again. Here is what I carry.
2014 Solera 24R
USN Retired
Old 12-05-2015, 08:04 PM   #5
There are two basic styles. Pull a fuse when you get it back and look at the profile. I can't remember myself exactly which ones, but looking at one will point you to the correct type. Then you can place your order with confidence.
Old 12-05-2015, 11:59 PM   #6
MNtraveler's Avatar
Thanks!! (Photo did not load)
2016 Forester 2401R
Old 12-06-2015, 09:37 AM   #7
Mikegjax's Avatar
Try this image. The other shows up on mine screen.
2014 Solera 24R
USN Retired
Old 12-06-2015, 09:56 AM   #8
That is called a ATC FUSE. It is just the size, under that is a mini, and about it a maxi. I would just buy the assorted atc fuse kit
clutchd is offline   Reply With Quote
Old 12-06-2015, 03:17 PM   #9
MNtraveler's Avatar
That's what I'm trying to figure out. There are a wide variety of assortments available to purchase. Apparently the ATCs are the "regular."
That worked, thanks. It that 25 amp at the top a maxi?
Bkgd. Info: there are six styles of blade fuse in automotive use today:
https://en.wikipedia.org/wiki/Fuse_(automotive)
Old 12-06-2015, 03:31 PM   #10
Mikegjax's Avatar
No "Maxi's" in that kit. I have attached the MB Sprinter Fuse Allocation tables that will give you an idea of the amperage's needed.
2014 Solera 24R
USN Retired
fuse
