Old 12-05-2015, 07:32 PM   #11
Send a message via MSN to Tiggerdad
Originally Posted by Skyliner View Post
Bleach may harm the valve seals. I personally have taken a liking to Odoban that is available from Home Depot and Sams Club. I got tired of Eucalyptus and am now using lavender or their lemon scent.
Odoban is incredible and it what I use on pet odors in my basement....my dogs are spoiled and when it is snowing or raining outside, they will urinate on the unfinished concrete floor. This stuff works awesome in disinfecting and elminating ANY odor!
Another example, our new "used" fifth wheel had mouse infestation in the heating system. The heater and the ducting were full or urine and the solid waste product of the animal's digestive tract. I removed the heater and sprayed and rinsed the heater with odoban and then flooded the duct work with odoban and used a wet dry vac to suck it out of the low point and my heating system smells better than new!
This stuff works and a little splash will take care of grey water and black water smells. I spray a bit in the toilet bowl too which helps greatly.
Amazon has favorable reviews for this product: http://www.amazon.com/Eliminator-Con.../dp/B000ZOQ9HY
It is strong so if you use it for other things, make sure you dilute it. The scent can be overpowering but will dissaipiate after a couple of days.
Ditto Ditto-Great stuff. Has been using it for years. Kills every kind of odors, is anti-microbial and a good mold killer.
I add nothing to my gray tanks.
2013 Crusader 330 MKS
2013 Chevrolet Silverado LT 2500 D/A
Tiggerdad is offline   Reply With Quote
Old 12-05-2015, 07:44 PM   #12
Yep, odoban is incredible for removing mold and mold smell from laundry that wasn't put in the dryer in a timely manner.
Skyliner is offline   Reply With Quote
Old 12-05-2015, 11:34 PM   #13
30 years of RV travel and I have never used any additive in the grey or black tanks. Just occasionally flush the blackwater tank.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
SSmbs is offline   Reply With Quote
Old 12-05-2015, 11:45 PM   #14
You must be one of those folks that won't use their rv bathroom because they thing it increases used trailer resale values or are you are trying to tell us your chit doesn't stink?
Old 12-08-2015, 03:48 PM   #15
2015 Forester MBS 2401W
HomeOnWheels's Avatar
Ok I'll keep Odoban around just in case.
I don't get how the diluted bleach can harm the system. Don't we use it to sanitize the fresh water tank?
Jeff
HomeOnWheels is offline   Reply With Quote
Old 12-08-2015, 06:47 PM   #16
Yes use chlorine for sanitizing but it is a small amount. Bleach is Chlorine and Caustic. Can damage the rubber seals on your valves. Next time you are in a big box store look up the parts section for toilets and read the info. Many will say not to use Chlorine bleach in the water tank because it can damage those parts.
Old 12-09-2015, 02:35 PM   #17
Pod2Vibe's Avatar
Also check your undersink one-way vents on your greywater plumbing.
Both mine were loose and you could smell the grey tank at times.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 12-09-2015, 02:56 PM   #18
dannyabear's Avatar
If the vent and air admittance valves are working, there will be NO oder.....
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 12-10-2015, 12:16 AM   #19
MNtraveler's Avatar
Nowhere near as much experience but I'm with you. Sink and shower drains to gray tanks have P traps. The toilet is fully sealed except for a "Mississippi-one" moment (if even that) while flushing. If any black tank odor sneaks in, it's due to running the exhaust fan while flushing which can be avoided by running it before and/or after, if that is even a problem.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
tank
