11-24-2017, 03:32 AM
Halogen to LED Headlight conversion
Has anyone out there replaced their stock HID headlight bulbs with LED bulbs from an aftermarket source?
If so, are you glad you did? Any trouble installing them?
01-06-2018, 10:49 AM
Hi namusmc. I am hoping to do this on my Sprinter soon … as soon the weather here (SW Idaho) warms a bit and the snow melts. I did change the H7 low-beams in my wife's 2003 Mercedes ML350 which has a very similar headlight design. Both vehicles use the same H7 lamp. I ordered the “XtremeVision 7G 72W 16,000LM - H7 LED Headlight Conversion Kit” from Amazon for $49.99. Each kit contains two lamps. Each lamp produces 8,000 lumens which is very much brighter than the factory installed lamps.
Since I did my wife's ML350 last week, I can write about that upgrade at the moment. I'll update here about my Sprinter 3500 after I get it done, although somebody else might comment sooner.
The ML350 was surprisingly easy to accomplish. However, the kit's instructions are a sparse. Also the kit does not include a retaining clip, so you need to either order one, or improvise. I improvised with a piece of bare wire which I used to tie the lamp clip into place. This was simple to do on the ML350 since the entire headlight assembly is easily removed. I ordering the extra clips for the Spinter since I don't think the headlight assembly easily removes on the Sprinter (hopefully somebody will comment about this). Also the XtremeVision instructions failed to state that lamp plug polarity does not matter (only an issue if you order this kit and know the DC polarity is often important – but not important here). As usual, I failed to take photographs of my progress – I'll try to remember to take pictures when I do my Sprinter.
As for illumination – Wow! Very much brighter! – Tremendous improvement. However, only slight improvement for distance of the highway illuminated. This latter issue is a mechanical adjustment for the low-beam vertical – in the case of the ML350, there is a metal shade inside the headlight housing which is adjusted to protect the vision of on-coming drivers. Replacing the lamp does not effect this adjustment.
Perhaps just my lone opinion, but I think the Sprinter's factory low-beam headlight illumination is dangerously poor. I don't drive much at night, but I really want to see the road when I do, an when alone on the highway, I see no reason why I should light up to world as much as possible. Hence, I am also considering replacing my high-beams with these LEDs, and also adding fog lamps as well.
Hope this has been helpful … I'll post about the Sprinter 3500 when it's done, and looking forward to reading what others have to say here.
01-06-2018, 10:58 AM
I do it to all my vehicles . Much brighter . If you have a big truck you might need to aim the headlights down a tiny bit to keep from upsetting the on coming traffic .
TV:GMC 2500HD Duramax
TT: 2015 Wildwood 21rbs
01-06-2018, 04:00 PM
Thank you for your helpful post. Good to know others are thinking about this relatively inexpensive halogen to LED headlight bulb upgrade.
Just finished converting my halogen Tacoma to LED and what a difference it made! Everything looks a bright white instead of a dingy yellow. Now looking at converting my Forester 2401W to LED.
I'm hoping there is sufficient clearance behind the stock Sprinter headlight housings to replace the bulbs without removing the housings.
Anyone else out there who has made this conversion on their Sprinter?
01-12-2018, 04:28 PM
The follow-up about upgrading the low-beam headlights on my 2015 Mercedes 3500 Sprinter with LED lamps. I was hoping to complete that upgrade today, but discovered a major issue that, for the time at least, completely stops me. The problem is in the way Mercedes mounts the H7 bulb as shown in the photograph below. Their mounting scheme makes it very easy to replace the existing bulb, but impossible to simply replace it with an LED unit. Somebody probably makes a mounting bracket that solves this dilemma, but I haven't found it. Perhaps someone has suggestions.
01-12-2018, 04:32 PM
Photographs of backside of headlight assembly with (1) lamp installed, and (2) lamp removed.
01-12-2018, 06:01 PM
Thank you for the pics. Very helpful.
It appears that the bulb is part of a special cartridge assembly and won't accept the elongated LED bulb. Hopefully, there is a Sprinter LED expert among our readers that has a good solution for this.
01-12-2018, 07:29 PM
Hi namusmc, referring to bulb assembly photograph, the H7 bulb plugs into the black assembly. Electrical contact is conducted through the assembly to contact points on its side, which twist-lock in place. There seems to be a variety of similar adapters available that might accommodate the LED lamps, but I haven't found any that specifically state "3500 Sprinter." There is plenty of room inside the headlight housing assembly to accommodate an LED upgrade.
I didn't describe access details inside the backside of the headlight assembly because I figured most interested folks can simply look at their own vehicle. However, I should mention that, without a mirror, it is not possible to actually see into the backside of the headlight assembly.
01-12-2018, 09:20 PM
Thanks again, Follow. If I find an adapter specific for 3500 Sprinter, I will share it here.
