07-08-2016, 08:35 AM
Has anyone added AC power surge protection to class-c Sprinter?
Wife and I are about to begin new ventures as we ready to purchase a class-c Sprinter, lease our home, and drive into a year of travel as we search for a new homestead. While we feel confident about our class-c MB Sprinter decision, we have not yet decided which make. We are persuaded toward a 2016/17 single slide unit with the diner, closet, and queen bed on the port side. However, I wish to add a few things to the motorhome which I believe will greatly enhance our boondocking comfort. While most of the things I wish to add are quiet simple, three items concern me because of available space or necessary coach modification, these are: 1) 300 watts roof-mount photo-voltaic, 2) whole-house reverse osmosis for freshwater, and 3) shore AC power surge protection.
Has anyone installed shore AC power surge protection to their class-c Sprinter? If so, how did you accomplish this? Any suggestions about how to best proceed?
07-08-2016, 11:37 AM
I think it depends which model
On the "s" model it's very easy. We put it in the compartment that houses the power cord. Not sure about the "w" or "r", but I'm sure someone will chime in
07-08-2016, 11:47 AM
I just finished an install of a 30 A Progressive Industry EMS on my 2015 24R. I'm a journeyman electrician. Using advice that I found on this forum I located the transfer switch for the shore AC and generator. The transfer switch was located under the big closet next to the fridge. I had to remove the drawer beneath the closet as well as an access panel beneath the drawer (remove six screws). I also removed one drawer bracket and the 1/4" wood bottom of the closet.
I pulled the 30A plug from the coach exterior to determine the color of the wire and used a meter to verify which line coming into the transfer box was from the 30A plug. I unwired the transfer switch and installed the EMS in series with the incoming shore power line. I added a short piece of 10/2 with ground on the load side of the EMS and wired it into the transfer switch.
I haven't mounted the digital display yet. I will probably put it in the closet above.
I put the EMS in line with the incoming shore power. There are possible issues with installing the EMS after the generator and shore power. I just want to protect myself from bad power coming into my coach from a campsite power box. The generator wiring is predictable and stable.
I hope this helps. This forum has so much valuable information.
2015 Forester 2401R MBS
07-08-2016, 12:38 PM
Greetings HVrunner ... thank you for the detailed information and the photographs of a nice install. This is very helpful. I agree with your decision to exclude the generator and only protect from shore power.
07-08-2016, 12:53 PM
07-09-2016, 01:32 AM
Originally Posted by HVrunner
I just finished an install of a 30 A Progressive Industry EMS...
I have the same, mounted underneath the rear bed adjacent to the transfer switch.
2016 Forester MBS 2401S
07-09-2016, 12:51 PM
Sprinter
I never vad a surge ussue a d I have just what you need: queen walk around bed, alcoa wheels, oorcebain toilet, nany upgrades, 2014 Prism 24g $73,500.
07-09-2016, 09:15 PM
I have the w floor plan and installed the surge inside the "nightstand" next to the bed. Plenty of room for it.
Progressive electronics- I have been very happy with it. I couldn't get power at one spot and I checked the monitor and it gave me error of reverse polarity. The campground had it wired wrong. Really can save all your electronics.
2016 Sunseeker W MBS
07-09-2016, 09:54 PM
RailwayRog
I managed to squeeze mine in behind the power panel and wired it so both shore power and generator power run through it.
I could only get two 100 watt solar panels on my roof.
07-10-2016, 04:25 PM
Thanks ... it good to know it fit there. Progressive Industries ... I agree, from the research I've done, this does seem like best choice. I has good ratings, good reviews, and useful features ... plus the price is too not bad.
07-10-2016, 04:26 PM
Thanks for that information. The roof real-estate is very limited. I could manage with two 100 watt panels if necessary. I would run a deficit each day which could be balanced when I hook up to shore power, or with the generator, if necessary. With Sprinter's limited resources it will be difficult to boondock more than a week, especially since the wife won't go too primitive. My budget already includes periodic full-hookup camping to dump, refill, recharge, and splurge.
11-20-2016, 09:00 PM
Well, we got our 2016 Prism at the end of August. I haven't posted in a while because we've been having too much fun. I installed a Progressive Industries surge protector. The only place I could find to mount it was under the bed, near the breaker box and fresh water tank. The hardest part was running the running wire for the digital display, which I mounter above the sink near the door. The Trimetric display is also mounted there.
11-21-2016, 01:04 PM
Read this post this morning while camping in Long Key Statepark. Off I went and asked 39 campers about surge protectors - none were using one and nobody ever had any problems without one.....
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - Sep 2021
Entegra 27A Oct 2021 - ?
11-21-2016, 01:12 PM
that's funny
I don't doubt that is true, but during the last 20 years of camping I'd say > 50% of the campgrounds I have been to have 'dirty' power. Under-voltage, reversed polarity (hot and common reversed), or open ground. All three are bad.
11-21-2016, 01:34 PM
X2 - and all it takes is one bad pedestal to do $5K worth of damage to your RV.
*And* Low voltage (especially at a crowded campground) Low Voltage will kill your A/C quicker than a surge will in fact!
We added a Hughes Autoformer to take care of that small issue
Bob & Anne-Marie [BamaBob & 6 Actual]
| 2017 Berkshire XLT 43A with Ultrasteer Tag | Blue Ox Avail + KarGard II |
| SMI AF-1 Air Brake | 2016 Jeep Cherokee Overland TOAD | Pedego Bikes |
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
11-21-2016, 02:04 PM
Bet that was fun … scurrying around a state park this morning asking 39 other campers about “surge protectors.” Hope you at least waited till after sunrise, had coffee, and remembered to put on your pants first … probably not a good time to be misunderstood …. We're each entitled to an opinion, and to spend our money as we see fit. Many folks choose to use prophylactic (electrical or otherwise), and some do not. Surge protection (transient suppression) is only part of the Progressive Industries unit. The unit also tests for proper electrical connection, and provides frequency, voltage and current information. Some folks think this useful, others think it useless … such is life.
11-21-2016, 05:01 PM
RailwayRog
Well said!
I know from my personal experience it low cost insurance and peace of mind.
So far I detected reverse polarity and low voltage at campgrounds.
11-21-2016, 08:34 PM
We've got one. Peace of mind.
Kelly & Mary Beth
2017 Forester MBS 2401WS
Kelly and MB
2017 Forester MBS 2401W Class C motorhome
11-21-2016, 09:21 PM
+1
2016 Forester 2401W newbie
11-23-2016, 11:29 AM
How would I add a surge protector to my 24r. Specifically where and how to I get to the area where the wiring enters the body on the driver's side. Is there an access panel somewhere? It seems to be about where the shower is? I'd rather have it mounted interiorly than on the post if possible.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
