Old 03-06-2018, 05:02 PM   #1
Hellwig Sway Bar
After reading several posts about the Hellwig sway bar I ordered one off Amazon and yesterday my brother in law installed it for me. I am thrilled with how much the handling is improved! My 2013 Solera felt like a marshmallow swaying down the road and now it is so much better. I totally recommend it if you don't have one. Also, it was very easy to install. Took him about an hour. The difficult part was doing the work lying on his back on the concrete.
Samsmomo is offline   Reply With Quote
Old 03-06-2018, 06:14 PM   #2
Mikegjax's Avatar
I also installed the Hellwig myself on 2013 chassis. Not difficult at all. Is well worth having for the improvements it provides.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 03-07-2018, 10:53 AM   #3
Loefflerh's Avatar
Maybe I am opening a can of worms here..
I had a Solera for 3 years and 35000 miles no Hellwig installed and I never saw the need for it. In my opinion that MH was handling just great..
Then I bought the Forester 2400W - it was handling just great, same as my Solera. It should have come with the Hellwig installed, but it didn't: the factory sent me the parts and I installed it myself. (That was no problem at all, about an hour or so).
And you know what? I do not realize any difference in handling and driving! (9000 miles without Hellwig and 8000 with Hellwig)
Maybe because I am always using a tire pressure of 80psi on all 6 wheels? I think that makes a lot of difference!
Hans
Retired military
Solera 24R Mar 2013 -Jun 2016
Forester 2401 Aug 2016 - ?
Loefflerh is offline   Reply With Quote
Old 03-07-2018, 11:06 AM   #4
Class C Representative
Joshua Cavitt's Avatar
When we first started using the Hellwig sway bar we took a test drive in one with and one without the Hellwig. The ride was significantly better. There wasn't much of a change when going forward or in reverse. We saw the change in ride quality going around corners. The new sway bar eliminated most of the stock sway back and forth.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 03-07-2018, 12:15 PM   #5
Mikegjax's Avatar
I noticed an improvement with the Hellwig reducing the big truck push. Some improvement in cornering.
2014 Solera 24R
USN Retired
Old 03-07-2018, 12:20 PM   #6
Rich.M's Avatar
X2
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 03-08-2018, 09:27 AM   #7
CharSolera's Avatar
X3. I also added the Helwig bar and Sumo Springs. Joshua Cavitt notes the improvement in cornering. Also less push from big rigs passing. Much easier to handle!
Charlene
and catpanions, Purrl & Lucy Lu
2014 Solera 24S
CharSolera is offline   Reply With Quote
Old 03-08-2018, 02:07 PM   #8
Char Solera, you are dead on. I replaced both on mine also, big improvement
lwalkplumb is offline   Reply With Quote
Old 03-15-2018, 03:01 PM   #9
oreddie
OREddie's Avatar
Ditto "I like it!"
Our '17 Forester 2401WS MB came with Helwig installed. I've owned 4 other brand Sprinter based RV's since W came out with the first View.
None had any special stabilizing equipment and more than once we had cabinets open as I tried to negotiate an uneven surface. Truck buffet and strong crosswinds made for tense driving.
In short, floor plan was why we went to look at the Forester. The vastly improved stability of the rig with the Helwig was the closer.
oreddie
'17 Forester 2401WS
OREddie is offline   Reply With Quote
Old 07-04-2018, 02:56 PM   #10
Hellwig loose bushings
Two questions regarding suspension upgrades.
1. Can someone verify the Hellwig sway bar part number is 8273? I misplaced the instructions that came with it. We have about 12,000 miles on our 2017 Sunseeker 2400W. We installed the Hellwig sway bar when the factory sent us one (should have been installed) shortly after we took delivery. This past week we had an engine problem and had it towed to a Sprinter dealer. They gave the suspension a once-over because the ride had worsened recently. We did go on some pretty rough roads over the course of a national parks tour. The dealer said the sway bar bushings were quite loose and should be replaced. Has anyone else had similar problems? Any suggestions on where to find replacement bushings?
2. I have been considering adding Sumo springs to the vehicle, but my extended warranty states that is a no-no and would void the warranty on the suspension. Has anyone had a similar issue? I think I might contact the warranty company to ask for a waiver.
Thanks,
Mike
Tall Guy is offline   Reply With Quote
Old 07-04-2018, 11:58 PM   #11
When installing, do the wheels need to be off the ground and on jack stands?
SOLD: 2018 Dynamax Isata 3 24FW...delivered 12 Ap 18
Mikemdd is offline   Reply With Quote
Old 07-05-2018, 07:26 AM   #12
Mikegjax's Avatar
No. The wheels do not need to be off the ground. You might need to raise the RV so you have room for access. Driving up on 2x8s under the wheels helps.
2014 Solera 24R
USN Retired
Old 07-05-2018, 10:54 AM   #13
Not sure of your part number, but I'd call Hellwig directly for replacement bushings - they've been helpful in the past...
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
sway
