Old 01-11-2019, 02:09 PM   #11
Who Dares, Wins
doc73's Avatar
I think it was quite a while ago where someone found the amount the Sprinter uses for DEF per mile and it was up north of 3 or 4 thousand miles per fill up. It does last a while and is usually easy to find just about anywhere that sells auto stuff (even Walmart makes their "own" brand now). I let mine run down low then fill to keep the fluid fresh. It does last a while in the vehicle but the fluid itself does not seem to have along shelf life depending on how it is stored.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-11-2019, 03:23 PM   #12
ACE110's Avatar
Can you explain a little more on the shelf life, ie what happens when it has reached its limit? Also, what are the good & bad storage practices?
ACE110 is offline   Reply With Quote
Old 01-11-2019, 03:36 PM   #13
While I don't have a Chevy, I have some experience with the DEF system on our Jeep that might be of interest. DEF does have a shelf life so you don't want to buy containers too long before using. I don't agree that it's caustic, but it does crystallize. It won't permanently stain paint even if it's dried and crystallized on the surface. I have been told by several Jeep dealer service departments that they see problems with crystallization in the DEF system as a result of using Blue DEF which seems to own a majority of the market. Cynics will immediately dismiss this as dealer bias trying to scare me into spending 3x for Mopar DEF, but I spend the money anyway. (To each his own.) I have a gauge and use that to track usage, and am pretty sure consumption is dependent on several variables (load, temperature, speed?); I have not seen a pattern of xx gallons/mile though I'm sure someone claims this is true. I refill when the tank is around 1/4 full to keep it reasonably fresh. While I don't know what the engine does when running out, I do know from experience what happens when the DEF injection system fails. In my case (Jeep) it did not go into limp mode but told me I had xxx miles, starting at 150 miles, before the car would not re-start if it was shut down. It was very clear about this, with the warning messages flashing at increasingly frequent intervals. I made it to the dealer with about 30 miles to go. If I had not made it, I could have simply kept the engine going while re-fueling (not a good practice, I know!).
Hope this helps....
Jack & April Connell
2017 Rockwood Mini Lite 2104S
Tow Vehicle: 2014 Jeep Grand Cherokee diesel
jackconn is offline   Reply With Quote
Old 01-11-2019, 03:37 PM   #14
Many vehicles have a gauge or an status indicator that you see when you scroll through all the other things on the vehicle. The DEF should have a gauge or percentage indicator that you can pull up and see. Don't know of any that are wait and see with an idiot light. Running out of DEF won't ruin and engine right away like running out of oil. The DEF is the governments answer to cleaner burning diesel... add some unknown cat piss smelling crap in a 3 - 6 gallon tank and make the test show better emissions to keep the tree huggers happy.
rlh1957 is offline   Reply With Quote
Old 01-11-2019, 03:40 PM   #15
Fifth Wheelers's Avatar
On my Ram truck I have a dial that shows the status of the DEF level. Not sure if you have a dial or light. If a light, you should have a reserve so you can get to a store. You will find out that when not towing you use very little DEF. When towing you use a lot more. DEF is only good for a year so I fill at a truck stop, you never know the age you are getting in a store. Plus it's a lot cheaper. Never heard of it being caustic since it is cow piss and water. Best.
2016 Champagne EL38
2016 Dodge Ram 3500 DWD
Fifth Wheelers is offline   Reply With Quote
Old 01-11-2019, 03:55 PM   #16
Mtnman64's Avatar
DEF
Originally Posted by vettecrazy View Post
We have the FR Sprinter, will turn 1,000 miles soon, we were just told by a owner of a Mercedes about the DEF, we have never added any. Think we have done harm?
Man , your dealer did a very poor delivery/instruction walk through with y'all. Make sure you read all the info on the MBS link on FR Forms to get a good working knowledge of your new RV.
Mtnman64 is offline   Reply With Quote
Old 01-11-2019, 04:02 PM   #17
Georgia Rally Coordinator
aceinspp's Avatar
Originally Posted by Walholler View Post
I have purchase many new vehicles in the past 50 years and each and everyone of them came with an owners manual. My last purchase was my first diesel power truck, slightly used at 8860 miles. The first thing I did after driving it home was to read the owners manual, it had a wealth of information in it both written words, diagrams & pictures. This information is from the manufacturer of the vehicle, not second hand info from an individual that may or may not have your best interest in mind. My truck holds 5 gals. of DEF which will last 5000 miles if I am not towing. If I am towing that mileage is cut in half. I get a information light and a message at 1000 miles remaining before I have to add more DEF and can manually pull same info up on info screen. I drive a Chevrolet 2500HD truck. I would suggest to you that you read your owners manual, anything that you do not understand can readily be found on the internet. YouTube is an excellent source of information on just about anything that you can think of.
Manufacture now do not furnish manuals which I found out when I bought my new Ram. Manual is in the apps setting what a pain to have to sit in a truck to read on a screen. They are getting cheap and it will eventually flow over to all manufactures. I ended up down loading the manual from there web site only 705 pages stupid. They make enough money on these vehicles that they surly can put a manual in the vehicle. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10 gear
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 67
Old 01-11-2019, 04:33 PM   #18
koller1509's Avatar
Best to store it at room temperature, Being stored at high temperatures shortens its shelf life.
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
Old 01-11-2019, 05:10 PM   #19
MBS DEF
We have a 2018 Forester MBS, ca. 2016 chassis. It has a DEF gage in the multifunctional group you can toggle to. It easily takes 2 1/2 gallons when it is below 1/4 on the gauge. I've added DEF one time and now have some 6200 miles on the rig.
Hope this helps.
John C
JOhn_R_C is offline   Reply With Quote
Old 01-11-2019, 05:25 PM   #20
milkman55's Avatar
Go through all your menus which are accessed with the steering wheel controls. You will see a visual gauge in 1/4 increments. I never let mine get below half full. I have make several trips over 2,500 miles and didn’t use half the DEF tank. I get the BlueDEF they sell at Walmart and it’s easy to fill. Pay attention to the warning about caustic overflow and wash away immediately.
I have about 10,000 miles on my Sprinter and have added DEF twice.
2017 Isata 3 24FW
2014 Honda CR-V
milkman55 is online now   Reply With Quote
