Old 01-11-2019, 07:14 PM   #21
Rodgers's Avatar
I have been using DEF in my 2014 since I bought it. DEF isn't caustic in any way, shape or form! If you should happen to spill some all you will see is a white residue. That can be washed off with water, no soap needed. If your's is like many others no matter what brand. It will warn you before it runs out. And may slow your speed down to what will seem like a crawl. Don't be afraid of DEF fluid!
Rodgers is offline   Reply With Quote
Old 01-11-2019, 08:08 PM   #22
SlowrideHD's Avatar
Correct Mr. Rodgers! DEF is not caustic...if it was, many of our internal organs would be in serious trouble. Urea, when dissolved in water is neither acidic or basic. As far as storage, you do not generally want it to be left in an open container. While it will freeze at 12F (-11C), the freezing and thawing of the 32.5% DEF does not degrade the mixture at all. The DEF tank in your vehicle will have a heater built in so that the tiny bit that is injected into your SCR system is thawed.
Big Brother has decreed that the NOX emissions from our diesel exhaust may be somewhat minimized by the addition of DEF. The ammonia produced by the hydrolysis of the urea reacts with the nitrogen oxide emissions and is converted into nitrogen and water within the catalytic converter. Of course our NOX would not be as high if they didn't mandate that a portion of the dirty exhaust was recirculated back into the clean intake air (which must be first cooled down within the EGR cooler). Also they have decided to severely restrict the exhaust flow with a particulate filter that has passages that are so tiny that they trap soot particles (which then must be burned away every few hundred miles) by wastefully injecting good diesel fuel right into the exhaust stream which ignites and creates an 1150F blowtorch that travels down the exhaust pipe and burns away the accumulated soot.
Aren't you glad you have a diesel now? HaHa
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 01-11-2019, 08:26 PM   #23
waybeck2018
waybeck2018's Avatar
I would caution any DEF user to make sure that the product purchased meets ISO 22241 specification. I purchase only the main known brand or one auto parts store has their name brand that meets the specification. Blue Def can be bought in many places and O'Riley sells both Blue Def as well as their name brand. Again, both meet the stated specification and it is clearly listed on the container. DO NOT buy Walmart brand at about half price. Cheap is not the way to go here.
waybeck2018 is offline   Reply With Quote
Old 01-11-2019, 08:39 PM   #24
Not from a cat, but it's the same chemical
Originally Posted by rlh1957 View Post
The DEF is the governments answer to cleaner burning diesel... add some unknown cat piss smelling crap in a 3 - 6 gallon tank and make the test show better emissions to keep the tree huggers happy.
I don't own a diesel and never have. My only experience with a Diesel involves a 32' U-Haul box truck trip from Philly to Raleigh in 2001. But I was curious about this stuff they dump in the exhaust system.
Here is a link to the Material Safety Data Sheet (MSDS) for Peak's Blue DEF product. The MSDS includes the chemical composition. It is quite straightforward. Blue DEF is 67.5% water and 32.5% urea.
The MSDS also states:
2. Exposure controls
Personal protective equipment : Avoid all unnecessary exposure. Gloves. Protective goggles.
and
7.1. Precautions for safe handling
Precautions for safe handling : Wash hands and other exposed areas with mild soap and water before eating, drinking or
smoking and when leaving work. Provide good ventilation in process area to prevent formation
of vapor.
Following are extracts from the Wikipedia article on Urea.
Urea is highly soluble in water. (I wonder if you could re-dissolve the crystallized urea in water and use it. You might need a hygrometer to get the dilution right.)
Many animals (e.g., dogs) have a much more concentrated urine and it contains a higher urea amount than normal human urine; this can prove dangerous as a source of liquids for consumption in a life-threatening situation (such as in a desert).
(This is where the cat piss comment comes from.)
Urea is used in SNCR and SCR reactions to reduce the NOx pollutants in exhaust gases from combustion from Diesel, dual fuel, and lean-burn natural gas engines. The BlueTec system, for example, injects a water-based urea solution into the exhaust system. The ammonia produced by the hydrolysis of the urea reacts with the nitrogen oxide emissions and is converted into nitrogen and water within the catalytic converter. Trucks and cars using these catalytic converters need to carry a supply of diesel exhaust fluid, a solution of urea in water.
Larry
Larry-NC is offline   Reply With Quote
Old 01-11-2019, 08:53 PM   #25
Who Dares, Wins
doc73's Avatar
80k miles on the cheap stuff.. Still going just fine.
I misspoke about the usage, it. Was based on the amount of fuel used, not milage (mpg changes on load).
Everyone else covered the storage and shelf life. It is mostly water and will freeze.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 01-11-2019, 08:54 PM   #26
SlowrideHD's Avatar
Curious. What information do you have about the Walmart DEF (assume you mean the SuperTech brand) that it is not suitable? Or is there something else?
IF a product does not adhere to the ISO 22241 standards, then that fluid cannot by definition be called a Diesel Exhaust Fluid (DEF).
Old 01-11-2019, 08:58 PM   #27
Who Dares, Wins
doc73's Avatar
Yep 80k miles of Walmart Def and truck stop Def (which is the other one EVERYONE seems to swear will destroy the truck. Guess I like to live on the edge..
2015 ChevyHD D-Max
Old 01-11-2019, 09:23 PM   #28
The MB has so many lights, I suggest reading the manual.
Go UK is offline   Reply With Quote
Old 01-11-2019, 10:36 PM   #29
Originally Posted by vettecrazy View Post
Thank you, so just look for the light. We should have been told this with this being our first diesel. I guess we have a spot that you fill it, we are aiting for a call from the service manager for education,
Yes, there is a separate fill point for the DEF. It is usually a blue cap somewhere. I know nothing about the MB so can't help you with where it is or even be sure that it is a blue cap.
Very glad that you asked, and shame on your dealer for not showing it to you. I have seen MANY pickups towed into the shop with very expensive damage, due to an unknowing person thinking that it was just a fuel additive. Seen several times that somebody who didn't know any better just dumped it into the fuel tank. That's a very expensive mistake.
2006 Chevrolet 2500HD CCSB Duramax/Allison
Demco 18k Autoslide
2012 Puma Unleashed 356QLB toy hauler
Toys - CRF250X, CRF250R, CRF450R, CRF150F, TTR230, TRX250EX
rmoore0852 is offline   Reply With Quote
Old 01-11-2019, 11:25 PM   #30
herbike's Avatar
DEF fluid is not caustic but it is corrosive. It is mainly liquified urea fertilizer. Here in the northwest it is manufactured by the same company that makes dry urea fertilizer, ammonia nitrate and explosives for the mining industry. Dyno Nobel is the company, they have plants in Utah and other parts of the country.
Here is their statement of the make up of DEF.
https://www.dynonobel.com/~/media/Fi...20Solution.pdf
Days camped in 15-180 days-16-95 days
17--114 days-18-71-days
19-0
2016 t28FQDX Shockwave, New Provider tires 10/31/18 ,TV-2015 LTZ Duramax with over 142,000 miles, with delete done, 2014 Polaris RZR 800 EPS/ 7900 miles
herbike is online now   Reply With Quote
