Old 02-04-2016, 08:20 AM   #1
Hood light and fan fix
The light in the hood, and operation of the exhaust are pitiful. Some others have changed the hood out for one made by fantastic fans, but I hate to waste the funds if I can fix. So I took off the little plastic cover over the light and replaced the bulb (921) with an LED from camping world for $15. But because its round and longer the the original bulb, not as much light got to the stove top as I'd hoped. But the attachment for the bulb is simply a part of the hood that was stamped out and bent upward. So I bent it down flush with the existing structure, sealed with aluminum duct tape and installed the new bulb. Voila! Two issues fixed. Much better light over the stove top, and much better air moving by the fan after sealing a couple of moderately large openings.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 02-04-2016, 09:28 AM   #2
Head Rambler
Good job. You've inspired me to look at ours and see if it's similar.
Gotta go campin!
Old 02-04-2016, 10:28 AM   #3
Islander's Avatar
backdoctor........
That looks like a good fix... I shall look for the holes to patch over as well.
I got tired of the exhaust fan having only 'off or on'...so I installed a speed selector switch so it doesn't sound like a small plane ready for take off while running.
It doesn't take much to open the outside flapper and on a lower speed setting it still directs the steam from a boiling pot outside....Bonus.. it is a lot quieter.
PS... while using the 'exhaust fan' be sure there is a window or a vent open (slightly) to allow air in to create the required draft .
hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 02-05-2016, 07:38 PM   #4
Couple things; in the future buy your LED's from China through ebay, you will save more than 50% with the only downside shipping time. Also, cut a small piece of pipe insulation and wedge it in the outside exhaust cover putting pressure against the plastic flap when in flight.
Old 02-06-2016, 12:38 AM   #5
MNtraveler's Avatar
Great fix - thanks for sharing!
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-24-2016, 05:08 PM   #6
LED bulb for hood
I found a flat LED panel that plugs right in and was $12 for 2 from Amazon. Big improvement.
Wrightwood is offline   Reply With Quote
fan, light
