Old 06-26-2018, 12:57 PM   #1
GeoDoc's Avatar
Hook BBQ to Prism Onboard Tank
I would like to hook up a portable grill to run off the RV propane tank.
A Weber Q would need to be converted from using 16 oz bottles,
A Nexgrill would need to be converted from using a 20# propane bottle.
I am leaning toward the Nexgrill.
What is the best way to tap into the big tank on the Prism?
Ron & Peggy
Punta Gorda, FL
2016 Prism 24M
2004 Bluebird M380 (sold)
GeoDoc is offline   Reply With Quote
Old 06-26-2018, 03:44 PM   #2
Buy an "Extend A Stay" inline tee. Costs $35 to $50+, depending on where purchased.
There are two taps on the tee and mine came with two hoses: one hose fits the BBQ grille (I bought a Coleman) and the other hose can be used to connect an auxilliary gas bottle to your system so you can "extend a stay".
You have to remove the hose(s) from the tee when not hooked up to the grille or spare LP tank, but the tee remains in line.
Mark & Susan
2016 Forester MBS 2401WS
Wrangler Toad
barnbnb is offline   Reply With Quote
Old 06-27-2018, 05:11 AM   #3
I did same on my 16 24R. I have a cuisinart. I put a shut off valve right before the grill. Works great and I ran hose under coach amd store unit in storage to left of entrance door. This way it sets up on its stand under awning. Next time I have it out I will take a picture.
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 06-27-2018, 05:57 AM   #4
Here is a link that might help. Propane Gear - Heaters, stoves, torches and all of the hoses and regulators to connect them.
2016 Vengeance 320A
2015 Chevy 2500HD LT 6.6L 4x4 ccsb Z71 trim
2012 HD Electra Glide
Andersen Ultimate Aluminum fifth wheel hitch V2
Days camped '16=43, '17=47, '18=57 '19=39
Electra glide is offline   Reply With Quote
Old 06-27-2018, 08:11 AM   #5
Fulltime family RVer
If you already have low pressure quick connects on your camper, Torjik makes a great kit for the Weber Q.
Ditch the little bottles- upgrade your Weber Q | Learn To RV
ependydad is online now   Reply With Quote
bbq, tank
