Old 07-17-2019, 03:51 PM   #1
House battery group and capacity
There are no labels on my house batteries to indicate the brand, type/group, or capacity. Need to know capacity to set up battery monitor, and type for eventual replacement. 2017 MBS 2400R. Two 12V'ers. And are there other groups with higher capacity that will fit under entry step?
a2badger is offline   Reply With Quote
Old 07-17-2019, 09:15 PM   #2
AudiDudi's Avatar
They are likely group 24's. Maybe ~150AH total so ~75AH usable. I think a group 27 *may* fit in some cases. The GC2's are too tall in my Prism.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 07-17-2019, 10:21 PM   #3
Senior
My 2017 MBS 2401WS came with 2 group 27 12 Volt batteries. I replaced them with 2 Group 31 AGM batteries with 125 AH. Also have 200 watts of solar on the roof and a TriMetric monitor and solar control to keep them charged.
sailski is offline   Reply With Quote
Old 07-17-2019, 10:27 PM   #4
Unfortunately my understanding batteries are supplied by the dealer if purchased new you can ask the dealer,. If purchased from a third party may ask them if known what you have. Hard to say at this point.
Theb2b is offline   Reply With Quote
Old 07-18-2019, 02:39 PM   #5
chroniekon's Avatar
You should be able to tell what group size your batteries are by their dimensions and likewise what will fit in a given space. Heres a link that may help.
https://www.batteryequivalents.com/b...ize-chart.html
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
Old 07-18-2019, 06:25 PM   #6
Thanks. So it looks like one of the 27's, but none of their dimensions is "right on." Is the height just the case, or does it include the posts? That's about an inch difference. In any case, looks like I can fit in any of those.
Old 07-18-2019, 06:27 PM   #7
I hadn't thought to ask the dealer -- I had figured Forest River supplied them.
Old 07-18-2019, 08:38 PM   #8
2012 Solera
I believe Motorhome batteries are factory installed.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 07-19-2019, 06:25 AM   #9
Usually if 2 6V true deep cycle batts are used in series (to make 12V) there will be a higher deep cycle capacity.
See Trojan for size and 20 hour rate amperage.
FFred is offline   Reply With Quote
Old 07-19-2019, 10:18 AM   #10
From the ones I've seen so far, the 6V ones are too tall to fit under the entry step battery box. Otherwise I would be going that route.
battery
