Old 01-15-2016, 04:50 PM   #1
MNtraveler's Avatar
How to add DEF
It seems pretty simple with this kind of spill-proof container - but the price seems ridiculous. Then again, $100 to have it done by a dealer? No way. Thoughts?
MNtraveler is offline   Reply With Quote
Old 01-15-2016, 05:17 PM   #2
Adding DEF
The easiest way to add DEF is to go to a truck stop. We have a filling station that you can just add DEF like you would when you add fuel. That is the cheapest way. Truck stops have to have DEF pumps because a lot of the semi's need it as well. Hope this helps!!
ratherbecamping is offline   Reply With Quote
Old 01-15-2016, 10:22 PM   #3
2012 Solera
I get the 2 1/2 gallon jugs from Pepboys, Walmart, etc. They come with a hose cap that fits the fill opening nicely. My 2012 Solera uses about one gallon every 1700 to 2000 miles. I add based on mileage and try to avoid having the warning light come on. On our MH the warning light comes on at about 4300 miles from full DEF. Won't quite take 2 1/2 gallons at that point.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 01-16-2016, 08:36 AM   #4
Homebrew's Avatar
I get 2.5 gal jugs with spout from Walmart, under $20 bucks. My truck hold 5 gallons but the gauge show almost full with 2.5 gallons.
XLR Thunderbolt 300X12HP
2014 Ram 3500 DRW
Homebrew is offline   Reply With Quote
Old 01-16-2016, 10:06 AM   #5
If you use the truck stops for DEF you may want to buy an adapter as some of them have a magnetic switch. The adapter is $14 Home - FiveStarDEF.com
2015 Siera 377FLIK
2014 Ford F350 KR
Maggie the new Chihuahua
Cricket the Chihuahua RIP
Steve & Jojo
stevewise is offline   Reply With Quote
Old 01-16-2016, 10:55 AM   #6
MNtraveler's Avatar
Good point. Does that filler have a full sensor, or do you have to watch the filler neck? I assume there is a sensor to avoid many messes at the pump.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
Old 01-16-2016, 12:07 PM   #7
The pump has the auto shut off the sensor does not interfere with that
2015 Siera 377FLIK
2014 Ford F350 KR
Steve & Jojo
Old 01-16-2016, 05:08 PM   #8
If you spill any just rinse the area off with water-DEF is corrosive.
2016 Sunseeker MBS W
2010 Honda CRV- SMI Stay In Play Duo
Previous-5th wheel, Class C, tent trailer, tent
SSmbs is offline   Reply With Quote
Old 01-24-2016, 12:01 AM   #9
MNtraveler's Avatar
