Old 09-25-2017, 10:52 PM   #1
Hub cap
Lost a rear hub cap on my Sunseeker (Sprinter). Can anyone recommend a source other than a MB dealer? Tia
Tollypop is offline   Reply With Quote
Old 09-25-2017, 11:15 PM   #2
Try Amazon they carry them thru RVWheel.com. They cost $95.00 for the rear. You may want to use tie wraps to keep from loosing another one as this is a common issue. Home Depo carries stainless steel tie wraps that work well. Good luck!!!
skorpion6591 is offline   Reply With Quote
Old 09-26-2017, 08:44 PM   #3
Thanks, very good info! Just ordered one
Old 09-26-2017, 09:25 PM   #4
Your very welcome! Like I mentioned before, there is an issue with the simulators coming off while driving. I found the stainless steel tie wraps at home depo and have worked well for me. They are cheap insurance and will keep them from coming off. Very important if you ever go with a TPMS unit. It is possible to loose the valve stem with the simulator which could be a serious issue. Just a little info to think about.
Old 09-28-2017, 07:02 AM   #5
we lost one, too
on the rear, and now zip tie them on. I will check into those stainless steel zip ties, though. Thanks!
2017 Forester 2401 R
Sunfish
Flying Scot #1146
jojoshort is offline   Reply With Quote
