Old 05-02-2016, 06:36 PM   #1
Install sumo springs in Tucson?
Any recommendations for where to get sumo springs installed on my Solera in Tucson? (Mercedes Sprinter 3500)
Thanks,
Steve
2014 Forest River Solera 24S
sclod is offline   Reply With Quote
Old 05-02-2016, 07:39 PM   #2
Depends, to some degree, on which version of the Sumo Springs you're installing. I installed the Solos, part # SSR-325-47, myself...here in Tucson. If you're looking at the Maxim, part # SSR-326-47-1, they look to be more involved. I don't know about the Sumos for the front - part # SSF-106-40, but they also look a bit more involved.
Installation of the Solos is pretty easy. Jack up the RV so the wheels are hanging (you may want to use jack stands...) then slide out the old bump stops and jam in the new ones. I think the only tool I needed beyond the jack was a screw driver to pry out the old one and jam in the new one.
In any case, I'd think any reasonable automotive place would be able to do it if they've got appropriate jacks. I had some work done at TCI Tire Center (W Glenn). They're mostly a truck tire place, so they have the right equipment. I don't know if they'd do this type of installation, but it would be worth a call.
YMMV
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 05-02-2016, 07:44 PM   #3
Blackrock's Avatar
Freedom RV installed my 5th wheel hitch and did a real nice clean job. They have a pretty nice service department. Freedom RV Tucson, AZ RV Dealer
2016 RAM 1500 - 2016 Keystone Laredo 265SRK
The road goes on forever and the party never ends.
Blackrock is offline   Reply With Quote
Old 05-02-2016, 07:51 PM   #4
Thanks, Dave and Blackrock. I'll check with TCI and Freedom RV.
Old 05-03-2016, 03:50 AM   #5
I installed #SSR-338-47 myself. You can do it yourself. As Dave told, we need jack stands(at least 21" lifted height) and screw driver or small pry bar. Good luck!
rvcamper
2015 Solera 24R
rvcamper is offline   Reply With Quote
Old 05-05-2016, 10:21 AM   #6
bob dirt's Avatar
They were very east to install. I used my rear stabilizer jacks with a 4x4 and a screwdriver to pry with. Took about 15 minutes total.They took quite a bit of sway out of my rig.
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 05-05-2016, 03:05 PM   #7
Pod2Vibe's Avatar
Thanks,
Steve
Buy them here for sure:
2015 Mercedes Sprinter SumoSprings | SuspensionConnection.com
COUPON CODES:
10EXTRA = 10% off your order total, excluding shipping charges
Please redeem your code on the final checkout page. Only one coupon code valid per purchase.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 05-23-2016, 01:17 PM   #8
I would not recommend the more aggressive sumo springs that bolt on. I installed them and the bilstein shocks now the ride is very rough. I will be removing the sumo's and replacing with the less aggressive type that just slide in.
rrock is offline   Reply With Quote
