Old 07-11-2016, 07:11 AM   #1
Is this right?
I have a new 2016 2400W, when I turn off the Battery disconnect switch the door step continues to operate. The door step switch on/off works but I would think the battery disconnect would turn off every thing,
Is it safe to assume there is no such thing as a system schematic available?
Skip51 is offline   Reply With Quote
Old 07-11-2016, 07:21 AM   #2
brookstone345sa's Avatar
You will find that other items are also still operating. On my 5th wheel, the front jacks and the carbon monoxide alarm still stay on. Best thing is to check what still works with switch off.
I ended up putting a switch directly on batteries to make sure everything is off, much better that way for storage in between trips.
brookstone345sa is offline   Reply With Quote
Old 07-11-2016, 07:23 AM   #3
Kenny kustom's Avatar
It's so, when you forget, and walk out the side door, no face plant!
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 07-11-2016, 07:41 AM   #4
SeaDog's Avatar
On my class A the steps were connected to the starting battery and did the same for the reason Kenny K said
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-11-2016, 07:42 AM   #5
Rich.M's Avatar
Battery disconnect does not turn of everything, you will find your Bigfoot stabilizers still work as well. These are some of the " parasitic losses". Either run generator monthly, take for a drive monthly or install direct battery terminal disconnect.
2015 Solera 24r
Rich.M is offline   Reply With Quote
Old 07-11-2016, 12:16 PM   #6
+1 on that. There'd be injuries galore!
2016 Sabre 36QBOK
2016 Sunseeker MBS 2400R + Diesel Gen
2014 Honda CRV
Blue Ox Flat Tow Equipment
SMI Stay-In-Play Brake Controller
ericlakin is offline   Reply With Quote
Old 07-11-2016, 03:37 PM   #7
Thanks for the replies
Guess I'll do some rewiring. Doesn't make sense to have everything normally off be off and everything normally on be on no matter what the battery disconnect position is. I also need to check which battery the stairs are connected to, It would be a *&^%&^$%^(& to find the cab battery dead because we went in and out a bunch.
Old 07-11-2016, 03:54 PM   #8
TURBS's Avatar
FYI I still wouldn't disconnect your co alarm.
Be looking for my post on this later today!
DO NOT DISCONNECT CO DETECTOR!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
Old 07-11-2016, 04:06 PM   #9
TURBS's Avatar
I'd advise you to not disconnect the co alarm.
2015 Columbus 320RS
2008 2500HD Duramax
Old 07-11-2016, 05:55 PM   #10
Sandiegodoug's Avatar
On my 2013 s
The co2 detector goes off when I use the disconnect switch to turn off house. There is a green light that goes off
Sandiegodoug is offline   Reply With Quote
