Old 12-15-2018, 08:48 PM   #1
Jack alarm?
I own a 2017 24 feet MBS Sprinter Sunseeker. I am wondering if there is an alarm that warns about retracting leveling jacks before shifting into gear...Merci!
Marc
Marc Gregoire is offline   Reply With Quote
Old 12-15-2018, 09:43 PM   #2
namusmc's Avatar
Marc
I think you have the same setup as I have, two Bigfoot stabilizers in the rear. No, there is no alarm or indicator when the jacks are extended.
I rarely use the jacks unless it is very windy. When I do use the jacks, I stick a post-it on the steering wheel to remind me. Even then, I visually check the jacks to make sure they are fully retracted before driving off.
Even if the system was fully alarmed, I would probably still do a visual check because of my quirky personality concerning safety matters.
namusmc is offline   Reply With Quote
Old 12-16-2018, 07:01 AM   #3
Mikegjax's Avatar
Marc
I use a spring cloths pin clipped to the gear shift cover to remind me. Have them labeled with name of item that needs to be retracted, removed, or disconnected. Very effective. Or sometimes I just listen for the scrapping noise .
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 12-16-2018, 07:43 AM   #4
There are now plastic hooks that can be stuck to a surface , and later removed with no harm.
Hang the ignition keys on a hook next to the jack controls.
FFred is offline   Reply With Quote
Old 12-16-2018, 04:13 PM   #5
Dbrote's Avatar
After forgetting to raise the jacks twice (although no damage) we use a printed departure checklist by the door that reminds us.
Dbrote is offline   Reply With Quote
Old 12-17-2018, 11:28 AM   #6
I have a 2017 also - no alarms - just the obnoxious scraping sound when you feel stupid after forgetting to raise the jacks. Like others - now a checklist item.
2019 Tiffen Allegro Open Road 32SA
F53 / 24000# Chassis
2008 Jeep JKS
Ready Brute Elite / Blue Ox BP
High Desert is offline   Reply With Quote
Old 12-17-2018, 02:14 PM   #7
vettecrazy's Avatar
We have a 2018 and we have a alarm, it is a beep, beep, beep, will not stop till you rise them. We have the 2400WS. The alarm wonít let you go anywhere till itís off.
vettecrazy is offline   Reply With Quote
Old 12-17-2018, 07:43 PM   #8
AudiDudi's Avatar
Originally Posted by vettecrazy View Post
We have a 2018 and we have a alarm, it is a beep, beep, beep, will not stop till you rise them. We have the 2400WS. The alarm won’t let you go anywhere till it’s off.
IMO, just one more sensor to fail and strand one. What ever happened to a walk-around before leaving?
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 12-17-2018, 07:52 PM   #9
vettecrazy's Avatar
For which we will gladly pay to replace when needed, this feed made me realize we are glad we have that feature!
Old 12-19-2018, 02:11 PM   #10
oreddie
OREddie's Avatar
Stabilizer Alarm
We have rear stabilizers on our .Forester 2401 WS. The switch label suggested there was an alarm but none went off when I accidentally moved off them. We were on soft gravel so no damage but a paved surface would likely have wrecked them.
Dealer found the alarm had not been connected during manufacture. It works well now.
oreddie
'17 Forester 2401WS
OREddie is offline   Reply With Quote
