Old 09-06-2016, 10:39 AM   #1
Jensen Dash Stereo System MBS Chassis
Has anybody had the audio sound cut out completely then back in every few minutes? Not power in and out, only all audio from in dash unit and all audio even if aux hookups.
BALLZITCH is offline   Reply With Quote
Old 09-06-2016, 10:51 AM   #2
Mine does and I have seen others mention on the forum. It's annoying.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 09-06-2016, 11:44 AM   #3
Sounds like a warranty issue to me then.
Old 09-06-2016, 01:27 PM   #4
Rkloud9's Avatar
Try searching the menus to turn off the nav system "voice". On ours, you really cannot shut the nav system down, and whenever the voice wants to chime in, even with its volume turned down and listening to a cd or the radio, the audio cuts out. Also, I found the nav system worked better with the voice off.
Bob & Cynthia
2017 SunSeeker MBS 2400W
Rkloud9 is offline   Reply With Quote
Old 09-06-2016, 01:31 PM   #5
Bob & Cynthia
Omg that makes perfect sense, will try that later today.
Old 09-06-2016, 02:10 PM   #6
You are not alone on this issue
Have the same system had the same issue
I tried the manual and felt stupid as I did not understand
I called the folks when I was in my unit and they walked me through it
I no longer have the cut out
Call ASA at 5742643135 and they can walk you through it
Sorry I can not remember what they did but they were great and now of the issue
Good luck
stervin is offline   Reply With Quote
Old 09-06-2016, 02:30 PM   #7
The only way I have found to shut down the nav when we do not want to use it is to delete the route. Otherwise it keeps trying to route you back to your last destination. It also stops some of the warnings. So of the one like speed limit and school zone you can just turn off in the settings.
2016 Forester 2401W newbie
Beachsailor is offline   Reply With Quote
Old 09-06-2016, 02:35 PM   #8
On Our last trip from Mass back to Florida we set a single route thinking that we could just continue on after stopping for the night. Then we started to get "Out of memory" errors. Then the menu button quit functioning and we had to turn off the system and turn it back on to get from radio or aux back to nav. We deleted the long route and a couple of other prior destinations and the problem went away. Has anyone else had this problem and is there a way to correct it?
Old 09-06-2016, 02:43 PM   #9
My radio cuts in and out on my 2016 Forester MDS. Also, one time it cut out for some time before the audio came back. I brought it to the dealer and they could not find anything. It's hard to fix something when it doesn't do it in the shop. It would be great to find out what the problem is.
jeitel55 is offline   Reply With Quote
Old 09-06-2016, 02:48 PM   #10
Jensen in-dash Nav
Brand new rig and I discovered I can't read anything in the GPS screen. My wife/copilot has to use a magnifier to read the writing. Is there a simple solution that we missed? Or go j need to spend $400 for the RV Garmin?
tmauceri is offline   Reply With Quote
jensen
