Old 04-14-2019, 09:39 AM   #1
Just purchased a used 2018 Forester
We are picking up our Forester MBS on Tuesday. We are buying from current owner and need to go through and check everything. It has only 3600 miles so the usage is very low. What are some things we should pay close attention to when we check it. Are the things that we should add to it to improve use and drive ability. So excited we finally found a Motorhome we both like.
lsconyers is offline   Reply With Quote
Old 04-14-2019, 09:48 AM   #2
fonzie's Avatar
You can use this check list to help with inspection.Also this thread might help.
PDI on 3171DS
RV Inspection Checklist
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-14-2019, 10:01 AM   #3
kenandterry's Avatar
Fonzie covered the “house” part for inspection.
Not sure why original owner is selling so soon, but just in case they gave up giving it some care and attention.....
Make sure all tire pressures are correct....this will greatly affect how it handles and therefore influence your driving impressions.
As soon as you can book it, change the oil and filter. If that’s still the original oil and such.....it would have newbie chunks floating around, and in the scheme of things......oil lube and filter is cheap insurance.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is online now   Reply With Quote
Old 04-14-2019, 10:26 AM   #4
PDI on 3171DS
Thank you
Old 04-14-2019, 10:27 AM   #5
Thank you. H
Old 04-14-2019, 12:35 PM   #6
We bought our Forester 2801 GTS about one year ago and it has been a great unit for us. Of course ours is a gasser versus your diesel but the #1 add on we did that made a tremendous driving difference was the Roadmaster Steering Stabilizer...took all of the play out of the steering wheel.
Past that we added a Victron Battery Monitor to accurately monitor the coach battery power as we find ourselves boondocking during some of our trips.
And our last accessory was a WeBoost to help with cell/internet signal and streaming when there is a signal out there somewhere.
Enjoy!
ArkRVHog
2018 Forester 2801 QSF/GTS
Little Rock, AR
Days Camped 2019 - 28 and counting
Days Camped 2018 - 49
ArkRVHog is online now   Reply With Quote
Old 04-14-2019, 02:20 PM   #7
Leatherman's Avatar
Just because it has fewer miles does not always equal low usage. Could have been parked for while and used as a temporary residence?
Bobby
2019 Nights Camped 4
2018 Nights Camped 31
2017 Nights Camped 35
2015 Palomino Solaire 201SS
2016 Ram 2500 Tradesman CTD
Leatherman is online now   Reply With Quote
Old 04-14-2019, 02:20 PM   #8
Congrats and welcome to the forum. Our Forester MBS just turned 3 years old and we've put 60,000 miles on it. I have learned a ton of good info from our fellow forum members!
You should be aware that this modern Mercedes diesel engine requires specific oil to protect the diesel particulate filter in the exhaust system. It does NOT use normal diesel engine oil. Ignoring this could lead to a very expensive repair. I do my own oil changes but it would not surprise me if your local oil change shop does NOT know about the special oil needs nor stock the right oil.
You can use Amsoil ESP Euro Oil or Mobil 1 ESP. (ESP stands for Emissions System Protection). The Mobil 1 often goes on sale on NAPA's website for about 40% off. Even if you have a shop do it, you could by it on sale and bring it to your mechanic to save money.
For engine fluids, Mercedes gives a spec number that when Googled produces a long list of approved fluids. Unfortunately, most of the brands are European and not easily found in the US. I did a lot of research and created this lube chart which I've attached for your convenience.
Also very important to know is that they prohibit any diesel fuel that's more than 5% biofuel, known as B5. You will sometimes see B20 diesel for sale at a much lower price but it should NOT be used per the owners manual. Some skeptics may reply here so I have also attached the Mercedes brochure on diesel fuel. It includes photos of the damaging effects of using B20 in their engines. You can make up your own mind......
This modern German engine is very high tech so you should read and follow the scheduled maintenance for the engine. I recommend finding a repair shop that specialists in Mercedes. The one i use has the same special training and equipment but charges at least 1/3 less than the dealer. If you're not a do it yourself like me, by using a Mercedes specialty shop you won't have to worry about all that Mercedes spec gobbly-gook that i had to figure out. They will already know all that and do it right. I also attached my own maintenance chart which I created from the manual.
Now for a word on Diesel Exhaust Fluid (DEF) usage. Every diesel brand and model of engine uses this stuff at a different rate, so you should only pay attention to what the owners of an MBS like us say. My indicator light first came on at 7,800 miles. My MBS uses it a gallon approximately every 2,500 miles which seems to be typical for an MBS. At that rate you can still drive hundreds of miles before the notices get more aggressive. So just add some at your next opportunity but don't worry.
As for the RV part, I've had LOTS of rain leaks so can your eyes open for water, stains on the ceiling and walls, etc. Get them fixed while you still have the warranty. Also had occasional trouble with the slide and other items.
Many of us here have installed and will swear by a holding tank vent that creates a air flow out of the tank to remove odors. It works really well!
https://www.amazon.com/Camco-40595-C...SIN=B01N8VS48F
I might mention that the Visa credit card from Fort Knox credit union rebates 5% for all fuel purchases. Many others may chime in about their 5 cent discounts, but this is FIVE PERCENT! Diesel is now over $3 here in southern OR (and FAR higher in CA), so that's a 15 cent per gallon rebate.
And I'm standing on the mountaintop and shouting praise to the SeeLevel tank sensor system. It's the best mod I have done to improve our RV experience! Thanks again and again to whoever posted about it when I first saw it.
Happy camping!
2015 Forester MBS 2401 WS
bob5560g is offline   Reply With Quote
Old 04-14-2019, 09:11 PM   #9
I've never heard,of the holding tank vent but I've also never had a problem with odors. I use dawn dish soap with calgon water treatment with water after every dump. You will get a countdown when it's time for an oil change its,based on either time as in 2 years or mileage. When the Def light comes on add the whole 2 1/2 gallon box as that's what it needs. We got our 1st oil change at a Mercedes dealer. It was $164. If you have the pantry with shelves the Container store sells plastic drawers that fit that space like they were designed for it. It makes usage alot easier than trying to get in that deep shelf. The sprinter section of the forum has alot of great tips.
Desertsquid is offline   Reply With Quote
Old 04-15-2019, 08:18 AM   #10
the main thing is the tanks, have them put water in all of them and check the sensors
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
forester
