04-18-2016, 12:33 PM
Klunk sound in MBS chassis on slow turns
I posted this over in the Running Gear tech forum. Please post any ideas there. Thanks!
http://www.forestriverforums.com/for...d.php?t=106024
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
04-18-2016, 01:03 PM
If you have the Hellwig sway bar, I would think the RV dealer would need to take care of it.
2014 Solera 24R
USN Retired
04-18-2016, 01:30 PM
X2 on the turn Klunks. 2016 R.
Dogpa
John Craft
dogpa
2016 Solera 24R
04-18-2016, 03:24 PM
The are sending me to the MB repair shop since it's chassis. I hope it isn't a turf war.
04-18-2016, 03:25 PM
Originally Posted by JLeising
Thanks - very helpful! I'll alert the mechanic to check for this. Seems to fit the bill since it clunks hard but doesn't break.
04-18-2016, 05:09 PM
Not sure but, isn't the Hellwig an FR install at their factory. If so, MB will most likely charge you for work performed that should be an FR dealer issue, since it's an upgrade outside the OEM swaybar fitted at the Sprinter factory. Just sayin'
04-18-2016, 05:19 PM
Kindly click here – a similar issue was raised on the other thread, and I responded there. The dealer have the MB serve shop do the work. This thread was intended as an informational cross-reference post. Thanks!
04-19-2016, 07:17 PM
Thanks for the heads up on the "intended as an informational cross-reference post"
04-19-2016, 08:30 PM
This was intended as a post to cross-link to the post on this topic in the wheels/axles/chassis forum, not to start a second discussion tread. I asked from the first post here to post any comments on the other thread. See post #1. I tried to be clear. I appreciate all comments and apologize if that was not clear.
P.S.: that earlier message should have read: The dealer *will* have the MB *service* shop do the work.
04-20-2016, 07:34 AM
Originally Posted by MNtraveler
I have a 2003 F-150 that has Clunked for years when turning slowly,,,
We have never been able to find what it is !!! Last time I had it @ the Ford Garage the Mechanic loosened & tightened every nut we could find,,, still Clunks ???
04-23-2016, 04:28 PM
05-03-2016, 06:57 PM
I had a clunking noise as well similar to the same thing others mentioned and found it to be the exhaust hitting the bottom of the coach where the exhaust exits on pass side
05-03-2016, 07:52 PM
The mechanic checked out everything underneath, but I will take another look at that myself. Thanks.
