Old 05-03-2016, 04:42 PM   #11
GM
bclemens's Avatar
Originally Posted by Joshua Cavitt View Post
Our tanks were always 9.8 gallons, not 12.8. The MBS and MBS only will be coming with a 16.8 gallon propane tank.
Tanks were 12.25 WC (Water Capacity or actual tank size), but you can only fill to 80%, so 9.8 LP capacity. Which is confusing because some mfg's list tank size (WC) and not LP capacity and leave the WC part in fine print.
So is the new 16 gallon tank, tank size or LP capacity?
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 06-01-2016, 11:30 PM   #12
Pls I need so help bclemens or Joshua. J3pferrell@frontiernet.net. We have a domestic fridge in our 2015 motorhome won't work.thanks. I can't start new thread,not sure why..
oakie47p is offline   Reply With Quote
Old 06-02-2016, 07:21 AM   #13
GM
bclemens's Avatar
What seems to be the issue? Almost everyone on this thread has a Dometic fridge...should be able to get tons of helpful hints.
You trying to run on electric or LP? Is the breaker tripped? Is the LP full?
Old 06-02-2016, 12:21 PM   #14
bclems ... Never did get an answer to your question, tank size or LP capacity?
rshellhammer is offline   Reply With Quote
Old 06-02-2016, 12:47 PM   #15
GM
bclemens's Avatar
No I did not. Joshua has been AWOL...I even texted him a while back and he did not respond.
I raised him better than that.
Old 06-02-2016, 12:56 PM   #16
Class C Representative
Joshua Cavitt's Avatar
Lies! You never text me!
The New tank is 16.8 gallons.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 06-02-2016, 02:41 PM   #17
GM
bclemens's Avatar
16.8 gallons Water Capacity or LP Capacity?
16.8 gallong LP capacity would be a 21 gallon WC
16.8 gallon WC would be 13.44 LP Capacity.
Old 06-02-2016, 02:58 PM   #18
Cmon boys. No quarreling, just the answer
Old 06-11-2016, 07:52 PM   #19
Just a Rookie
With regard to the Dometic fridge problem, ours would only work with LP regardless of the AC source until we tripped and reset the GFI near the sink. I learn something worthwhile with each new malfunction…..
John and Shirley
2015 Sunseeker 2400RSD
2006 GMC 2500HD Duramax
Spokane, WA
717 Jock is offline   Reply With Quote
tank, modifications
