Originally Posted by Rogerbruchay
Just wondering if anyone has ever had a problem with the fresh water tank filling while hooked up to city water? I know there is a check valve somewhere, but where? And suggestions would be appreciated. Thanks.
It is usually in the water pump itself. Mine leaks on occasion as well.
To reset the valve
I turn off city water and depressurize the system.
With water in the tank run the water pump and pressurize again running a small amount of water is good as well.
Turn off the pump and depressurize again.
Turn city water back on.
It should no longer leak water into the fresh tank.
Optionally if it keeps happening you can add another check valve before your pump or even a maunual valve but I have not reached that point. The valve you have to remember to manually turn when switching between fresh and city water.
I now leave my fresh tank open or watch my fresh tank level when camping with it closed as I don't want pressure on the tank to cause issues from city water hook up.
