07-12-2016, 07:23 AM
Leave fridge on or not when storing between trips?
Another in a series of newbie questions ... what do you leave plugged in and power on when storing the coach between trips? My partner and I are having on ongoing debate as to whether to leave an empty fridge running while our new Forester MBS 2401W sits in covered storage facility between trips. Does the fact that we live in hot, humid Houston TX make a difference in the answer compared if we were in a less mildew-prone environment?
Appreciate any advice!
Kelly
Kelly and MB
2017 Forester MBS 2401W Class C motorhome
07-12-2016, 07:38 AM
If your emptying the fridge then you can keep it off. just prop open the door and put in some backing soda boxes to keep odors down. if you leave the fridge closed with nothing in it then there is possibility of mold starting. best to crack the door open to let air cycle thru it. We always have something in our fridge and leave it running as we are stationary at a campground with the electric plugged in.
To run a fridge with nothing in it doesn't make much sense to me...
Hope this helps.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
07-12-2016, 08:02 AM
Hope this helps.
Agree!
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
07-12-2016, 08:06 AM
I agree, leave it off and prop it open, my fridge and probably yours as well has tabs that will keep it from fully closing while we are not using it. This allows it to dry out completely and reduce the probability of odors and mold.
Shawn
Chief, U.S. Coast Guard Reserve
2019 Sport Trek ST270VBH
2018 Chevy Silverado Z71
07-12-2016, 08:09 AM
And, be aware that on some models, when door is open the interior light stays on. You may want to remove the bulb if leaving the door open.
2018 Forester 3011 DS
07-12-2016, 08:18 AM
good point, but If you use those slide out tabs the doors should close enough to keep the light off (at least in my case it does) and still allow some airflow to keep things dry.
Shawn
07-12-2016, 08:22 AM
I agree. I remove those bulbs anyway, because I boondock quit a bit and they just use up energy, esp. if "someone" leaves the door open
07-12-2016, 09:49 AM
When stored we empty fridge and use those tabs to prop open. We also leave a few gallons of water and chemicals in the grey/black tanks. Have a battery disconnect on the negative side that shuts off all power to everything.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-12-2016, 11:36 AM
Definitely turn off. Let freezer defrost and wipe out water condesate. Then prop doors open with the blue clips to allow to fully dry. Otherwise you will get mold.
07-12-2016, 11:43 AM
You guys are The Bomb! Thanks a bunch!
Kelly & Mary Beth
Kelly and MB
07-12-2016, 01:03 PM
Not to confuse the issue, but 😁
We leave ours plugged in with the settings at the highest temps with baking soda and non-perishables in it.
Why, you ask? We did the same with our park model fridge and it is still running strong after 12 years. Virtually everyone else that turned them off when they left died after 7-10 years.
Personally, I'll deal with a little energy charge versus chancing replacing a fridge in an RV.
07-12-2016, 01:45 PM
Important to make sure that your trailer is level if leaving on full time. Out of level can degrade the fridge's performance over time.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
07-12-2016, 01:54 PM
My TT is plugged in, water on, refrig on and in use, making extra ice all the time, while it's in my driveway.
FROG AR-0019-242
07-12-2016, 02:20 PM
After having a refrigerator system rebuilt, the person at the facility cautioned us on frequent shutdowns. He said that the tubs collect condensation even though they are "potted" in Styrofoam. This gives them a perfect environment to corrode and then leak as mine had. So, if we are not going to be going out again in the next several week or are not sure, we leave the refrigerator on. Otherwise if it's going to be, say, three weeks, we shut it off. The cost of having the unit rebuilt or a new replacement unit, will cost more than the electricity your refrigerator will use in the camper's lifetime!
07-12-2016, 03:43 PM
We leave our RV at the lake for use as a getaway when not on the road. Haven't turned off the frig in 6yrs. While leaving drinks and food items in the freezer and frig w/o a problem and no waiting for it to cool before putting more food in it for a trip. As to energy cost, couldn't be that much and well worth it because it makes the wife happy, very important.
cruisin
07-12-2016, 03:57 PM
Our Lexi is parked next to our home, and when not on the road, is plugged in 24/7, 30 amp. Fridge stays on 27/7, except when stored for winter, Nov thru Feb.
Was told the same as previous member stated...constant on off on off is worse than leaving it on 24/7.
I also look at the full timers who are living in their rigs, and who have to run it 27/7 for looooong periods of time.
Grumpy
Steve & Cheryl + Zoey, and Ziggy, our furry kids.
2012 Forrest River Lexington 283ts
Toad, 2013 Subaru XV Crosstrek
07-12-2016, 04:02 PM
Georgia Rally Coordinator
With my newer Dometic frig the light only comes on when the frig is turned on. You can leave door open other wise. Later RJD
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
07-12-2016, 06:40 PM
Continuing to learn ... Thanks, all.
Kelly & Mary Beth
Kelly and MB
07-13-2016, 11:01 AM
That's where I keep my extra beer cold.
2014 Rockwood 8289
2013 Toyota Tundra
07-13-2016, 11:43 AM
Hope this helps.
Yep!
2016 Flagstaff 27VRL Emerald
14K Equalizer
2020 Silverado 2500HD CC 4X4 6.6L gas 3.73
