Old 10-18-2016, 09:38 AM   #1
LED's wont light up
On the front of my 2016 MBS 2400W mh there are two led light strips above the cab. Only one side lights. Has anyone else had this problem and if so how did you resolve it?
Zcamping is offline   Reply With Quote
Old 10-18-2016, 10:17 AM   #2
SeaDog's Avatar
grab a ladder crawl up there and pop the cover for the light and see if a connection has come loose, check your ground connection and for voltage with the lights turned on. It may the led element has burned out if you replace with the same.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-18-2016, 11:22 AM   #3
This is one of the LED strips. No cover and cannot see a way to check for voltage.
Old 10-18-2016, 11:42 AM   #4
SeaDog's Avatar
OK you may have to go inside and look up inside of the area above the drivers and passengers area at the front cap and see if something has come loose. It may require removing some panel On my Class A that area was open behind the cabinet doors.
Retired Navy
AF&AM of Idaho
led, light
