Old 10-13-2016, 01:54 AM   #31
bob dirt's Avatar
[QUOTE I'm still looking for (2) valve-stem stabilizers (rubber grommets).
[/QUOTE]
They have them here...
Alcoa Wheels | Steel & Aluminum Truck Rims Buy Truck Wheels
That's where I got mine.
***I also have a full set of covers and 4 steel wheels for sale cheap. I am in Phoenix
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 10-14-2016, 06:20 AM   #32
Oh great, thanks a lot ;)
Originally Posted by nusslejj View Post
Here is a link to a couple pictures of the Alcoa Rims. I'm still looking for (2) valve-stem stabilizers (rubber grommets).
https://1drv.ms/f/s!AthDbJ0kaDaPh0355t1s_wPJFJMl
You just cost me a couple thousand dollars
Those wheels look really good. Going to give myself an early Christmas present and put Forrest on a diet.
Any issues checking/adjusting tire pressures?
KatanaPilot is offline   Reply With Quote
Old 10-14-2016, 11:50 AM   #33
Easier to check tire pressures
Nope/nada/nunca/nyet. The fronts are easier to check than the factory rims+hubcaps, and the rears are about the same. I'm currently looking for rear valve-stem stabilizers. The oval hole is ~ 3.5" x 1.5".
The new Alcoa Evo? model has round holes.
I am sure you have already realized that wrt rotation - the tires will have to stay where they are unless you want to pay to have them removed from the rims.
I just started working for Goodyear (Corporate HQ), so I don't care if I burn through tires...
Let us know when you have them bolted on !
nusslejj is offline   Reply With Quote
Old 10-14-2016, 10:33 PM   #34
What about with 6 wheels?
I think the other option is to replace all 6 wheels with the Alcoa's and then you can rotate the rear inners to the fronts. There appears to be some confusion about whether or not the MBS wheel studs can support the additional thickness of the Alcoa wheels when you replace inners and outers - but Alcoa has a tech bulletin that says you can. Additionally, Leisure Time offers the aluminum wheels as an upgrade and they install 6.
Not cheap, but what a great improvement in both appearance, weight reduction and functionality.
Thanks for the pictures!
Old 10-15-2016, 07:55 AM   #35
Two issues rotating Alcoa rear 'inner rims'
Before you spring for 6 instead of 4, consider these 2 issues -
1. The Alcoa's only have a polish/finish on one side. Maybe you can purchase the finish on both sides, but I am not aware of it.
2. If you look at your inner steel rims, they are all marred/rusty where they contact the outer rim. I bet if you purchased inner Alcoa's, they would also become marred and ugly - and that is the side that will face 'out' if you move them to the front.
Old 10-15-2016, 08:04 AM   #36
Great point
Had not thought of that and you are correct. The Sprinter wheels are not available polished both sides. Guess I'll just rotate the tires once when I install the new rims.
Old 10-16-2016, 02:02 AM   #37
raptor's Avatar
If they are going to be uglier anyways. Keep your old steel rims and $3600.
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
cover, wheel
