Can’t find low water drain. Have looked under circular hatch on fresh water tank only see Fresh tank drain. Some posts suggest they are pushed up inside but I can’t see or feel any. Also looked passenger side behind door.
Should be just aft of the electric step, sort of under the kitchen cabinet area. There will be 2 of them--one hot and one cold water line.
Mark & Susan
Former MBS 24R and 2401W Owners
Just recalibrating our camping set-up for now!
I have the 2016 W and the low point drains are definitely in the circular hatch where the fresh water tank drain is.
The drain valve is in the winterizing area, turn it open a your tank will drain out the back half. It’s where u suck in the anti freeze. This is on my 2401r MB’s FR. 2016
On my MBS 2401W I found the hot and cold drain points behind the coroplast in the right back corner. They are not near the fresh water drain access plate. I cut a hole in the coroplast so that they could extend through and be more readily accessible.
