Old 07-01-2016, 09:57 PM   #1
Phinias's Avatar
Mattress in 24R
How do I access under mattress. Not the cabinet doors but through the top. The panel that the mattress rests upon.
Phinias is offline   Reply With Quote
Old 07-02-2016, 04:33 AM   #2
You go outside the rv and open any one of the three doors back there.
The mattress rests on the top of the rear storage compartment.
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 07-02-2016, 08:32 AM   #3
Phinias's Avatar
When the slide is out my cat goes under there. I need to make sure he is not getting into trouble with wire or whatever.
Old 07-02-2016, 12:51 PM   #4
We haven't had a problem with our cat when he's in that space, except when he climbs down into the space behind the cabinet door. We are not sure if he can climb back up so we leave the left door open if we are away. When we bought our 24R, they showed us that you can lift the close half of the bed - I believe it's hinged at the front. Anyway, our unit has 2 wires that cross through the area and more wires behind right cabinet with water filter. I don't think it's a problem unless your cat likes to chew wires or is a kitten small enough to climb into the area we with the water filter.
HappyHikeRs is offline   Reply With Quote
Old 07-03-2016, 06:41 AM   #5
Phinias's Avatar
Thank you Happy hiker. That's what I suspected. Charlie has been hard at work removing the foam sealing around the plumbing behind the right door, from the inside. Feel better that it's not from directly under the bed
Old 07-03-2016, 12:01 PM   #6
On our 2016 2401R, when the rear slideout is extended and mattress removed the wood platform is hinged and can be lifted to get underneath bed. It lifts towards the front of RV.
2016 Forester 2401R MBS
Trekker Low Profile Cap
Wrightwood is offline   Reply With Quote
