Old 08-06-2018, 03:03 AM   #1
namusmc's Avatar
MB Chassis battery maintenance
Does anyone know if the factory chassis battery is maintenance free or needs distilled water occasionally. It's not the easiest thing to get at under the driver's side floor.
namusmc is offline   Reply With Quote
Old 08-06-2018, 05:17 PM   #2
Rich.M's Avatar
I haven't bothered to look under the drivers floor and I don't think I'm the only one. No replies on my string asking if anyone has had a battery fail. I guess they last a long time without problems. Someone with one of the older MBS units should have cooked out a dry cell by now if they were wet cell.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 08-06-2018, 08:48 PM   #3
namusmc's Avatar
Thanks, Rich. I guess no one here has checked their MB chassis battery.
Old 08-07-2018, 12:21 PM   #4
Rkloud9's Avatar
I too am guilty of not checking that battery. I do know it is a high quality AGM battery, and lasts a long time.
Bob & Cynthia
2017 SunSeeker MBS 2400W
Rkloud9 is offline   Reply With Quote
Old 08-08-2018, 01:34 AM   #5
namusmc's Avatar
Is AGM the gel cell type of battery?
Old 08-08-2018, 04:36 AM   #6
RCW
Yes, it is.
RCW is offline   Reply With Quote
Old 08-08-2018, 07:50 AM   #7
I've been into the battery a number of times. There is a connection to the coach batteries there, and mine was loose and arcing. Burned a hole in the top of the red plastic cover and created voltage fluctuations that drive the MB computers crazy! 7 pages of trouble codes.
Anyway, it's a sealed unit that doesn't appear to require water top ups.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 08-08-2018, 02:54 PM   #8
jkoenig24
Sprinter batteries are sealed and, no owner service is needed.
jkoenig24 is offline   Reply With Quote
Old 08-08-2018, 03:04 PM   #9
Yes, it is a maintenance free battery.
2015 Solera 24R
2014 Mercedes Chassis
Karter is offline   Reply With Quote
Old 08-08-2018, 05:23 PM   #10
camaraderie's Avatar
While AGMS are maintenance free...not all maintenance free are AGM. Many are simply valve regulated wet cells with a deeper water reservoir which enables them to be sealed and maintenance free.
I believe though that the Sprinter batts are AGM's
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
battery, maintenance
