Old 10-12-2015, 01:48 AM   #1
MBS 2401S has "Above Floor Slide" instead of Schwintek?
The Forester MBS 2401W and 2401R both have Schwintek Slides. Why does the MBS 2401S have the Above Floor Slide?
qtran is offline   Reply With Quote
Old 10-12-2015, 12:57 PM   #2
Class C Representative
Joshua Cavitt's Avatar
The S slide is bigger, heavier, and is engineered differently. That's why it gets the above floor slide.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
Old 10-12-2015, 01:24 PM   #3
Thanks for the reply Joshua. Isn't the W floorplan 33% longer than the S? Also, the S only has the dinette and wardrobe in the slide while the W has same with addition of queen bed in the full length slide. I am sure I saw schwintek slides in the W.
Old 10-13-2015, 08:27 AM   #4
You're correct there are Schwintek slides on the W. We would do the Schwintek slides on the S but the way the slide is designed there isn't enough room on the sides for the Schwintek slides.
Old 10-13-2015, 11:37 PM   #5
TARVIDSON
I have a Prism LE2150 with Schwintek 2 motor slide and a floorplan very similar to an S and it is above the floor with the dinette and wardrobe in the slide. What is the difference between the S and the Prism?
TARVIDSON is offline   Reply With Quote
Old 10-14-2015, 09:19 AM   #6
Coachmen and Forest River Class C motorhomes are two different divisions with two different engineering process'. The way our slide is designed we have to use the above floor slide.
slide
