Old 02-15-2016, 11:14 PM   #1
MNtraveler's Avatar
MBS Front Stabilizers
The rear stabilizers are fairly effective, but the front could still use some support to stop the remaining movement when parked. I've looked under the front a couple of times and I'm puzzled where would be a good place to put stabilizers that would not require reaching about 2' underneath to position them carefully and avoid breaking something. That far under makes it hard to crank them up as well as install and remove such as when the ground is wet. Has anyone had any luck with this? Thanks!
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-16-2016, 08:38 AM   #2
I have not tried anything on the front, but I have thought about it.
I'd probably look to the front wheel jacking points as a likely spot...
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is online now   Reply With Quote
Old 02-21-2016, 11:04 PM   #3
MNtraveler's Avatar
I'll have to look for those - need to learn where they are anyway. Not that I'll ever be jacking this thing up! (Hopefully not!) I also need to look for that supposed jack under the floor on the passenger side. RV is in the driveway charging up so I can do this tomorrow with luck.
2016 Forester 2401R
Old 02-23-2016, 10:35 AM   #4
hkreck's Avatar
MNtraveler
I installed big foot stabilizers on the front of my Solera last year, the location for them is hard to get into but it can be done. If you go into Quadra's web site they have all the info about the front stabilizers on the Sprinter chassis.
Henry & Tena
2013 Solera 24S
The Great Escape
hkreck is offline   Reply With Quote
Old 02-23-2016, 10:48 AM   #5
What was the part# for the front stabilizers? Did it take long for install?
Dogpa
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 02-23-2016, 12:11 PM   #6
hkreck's Avatar
Part #QE12PT-12, Two point system, 12" stroke cylinders, two point pump system W/ weather proof control box. I wasn't able to work on it at my home at the time due to street work so I had to work on it else where which caused it to take longer to do. I'd guess if the Irish guy (Murphy) stays out of the work it could be done in 4-6 hours
Henry & Tena
2013 Solera 24S
The Great Escape
Old 02-23-2016, 01:11 PM   #7
Great info Hreck.
Dogpa
John Craft
dogpa
2016 Solera 24R
Old 02-24-2016, 01:46 AM   #8
MNtraveler's Avatar
Thanks for the info!
2016 Forester 2401R
Old 02-25-2016, 02:12 PM   #9
GM
bclemens's Avatar
I am about to proto a 4 point leveler from Quadra here shortly. I'll let you know how it goes. My only concern is a 70 lbs (net) weight gain over the 2 point system.
PLEASE do not send questions via Private Message. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only. Our owners manuals are available online and via iPhone/Android Apps. http://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-25-2016, 03:44 PM   #10
MNtraveler's Avatar
Wonderful! In my opinion, a 4-point leveling system would be a huge marketing plus and would be worth the weight. Adding another two-point unit would not be that helpful. I'm not sure the feasibility of leveling using two 2-point systems (such as adding a 2" block under one side - not sure that would even work) but I can guarantee owners will try whether or not told not to. ;-)
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
stabilizers
