Originally Posted by sailski
My best guess is that 61 lbs is great for a work truck where you unload it at their end of the day but not for a Motor home that always remains with most of it's load and is at or near it's max when you drive it.
Hmm. The 61 lb. (or thereabouts) pressure recommendation is actually based on a tire pressure table. This link is for a fairly exhaustive document on tire pressure from Goodyear:
http://www.goodyeartrucktires.com/pd...dinflation.pdf
One of the first tables in the document includes the MBS LT215/85R16 tire type. My Solera has Continental Vanco tires, but I couldn't find similar info online from Continental. That being said, I did find a few tables from other manufacturers and it appears that all tires with the same specs (LT215/85R16) have the same recommended pressures.
Note that there are different "load range" letters associated with the LT215/85R16 tire size. The load range letters (C, D, or E) reflect the maximum load & pressure for a particular tire. The Vanco's are load range E, with a maximum pressure of 80 psi. But the recommended load and pressure values are the same regardless of the load range - you just can't go to as high a load / pressure on a D as you can on an E.
Dave
