Old 02-19-2019, 08:13 PM   #1
MBS Regeneration
Why driving your MBS, how can you tell when your coach is going thru itís regeneration process. Is there anything that tells you this so you could get a feel for how often this happens and maybe change driving habits to decrease the frequency and maybe improve fuel economy.
rotdoxdad is offline   Reply With Quote
Old 02-20-2019, 07:42 AM   #2
Drive as much as you can at speed , do not idle for long periods of time, is about all you can control.
FFred is offline   Reply With Quote
Old 02-20-2019, 11:12 AM   #3
Mikegjax's Avatar
Originally Posted by rotdoxdad View Post
Why driving your MBS, how can you tell when your coach is going thru it’s regeneration process. Is there anything that tells you this so you could get a feel for how often this happens and maybe change driving habits to decrease the frequency and maybe improve fuel economy.
I have slightly over 50,000 miles on my 2013 MBS. My iCarsoft MBII scanner shows I have never had a regeneration occur. If you are doing mostly highway and little city driving, not much idling you should not have a regen. very often.
Supposedly you would notice a decrease in performance during regen.
BTW, if you take MBS in for servicing the dealer can tell you when you had your last regen. Just ask them.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 02-21-2019, 05:51 PM   #4
new to MBS Sprinter. What is regeneration and why does it occur? There is no info in the MB manual on this.
2019 Sunseeker 2400WSD
JimHs1 is offline   Reply With Quote
Old 02-21-2019, 06:02 PM   #5
From what I've gleaned over the years...
Modern diesel engines use a "diesel particulate filter" to remove soot / particulates from the exhaust. Heating the filter to high temperatures burns out the stuff that's been caught in the filter, allowing the exhaust to flow freely through the filter. If the engine is running at high enough load for enough of the time the filter doesn't get clogged. But if the engine is running at low power or idle, the exhaust isn't hot enough and the filter gets restricted.
A "regeneration" cycle artificially creates the heat needed to clean the filter if the filter gets too restricted.
Here's an article on diesel particulate filters and regeneration:
https://en.wikipedia.org/wiki/Diesel_particulate_filter
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is offline   Reply With Quote
Old 02-21-2019, 08:59 PM   #6
Mikegjax's Avatar
Dave
Spot on Dave.
2014 Solera 24R
USN Retired
Old 02-22-2019, 12:53 AM   #7
AudiDudi's Avatar
Twice after shutting off the engine in a parking lot after driving for a while, I have heard the exhaust "popping and clicking". I'm guessing I interupted a regen.
Mike and JoAnne
Montana Summer / Arizona Winter
2016 Prism 24G /2002 HitchHiker 38LKTG
ACME EZTowing a 2015 Chevy Sonic RS Hatchback
AudiDudi is offline   Reply With Quote
Old 02-22-2019, 02:09 AM   #8
MNtraveler's Avatar
Unless you are hearing something different, popping and clicking is typically the hot exhaust lines and especially the catalytic converter cooling down and the metal contracting here and there.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
Old 02-22-2019, 06:32 AM   #9
There is one caution to never ideling a MB.
If you do a long hard pull , up rocky top,and pull into a rest stop , you should allow the turbo about 3 min to cool.
THe turbo will be working hard and be very warm and stopping the engine will stop the lubricating and cooling of the engine oil flow to the turbo.
The lube oil can cook," coke" in the oil passages which can block future oil flow.
In a campground there is plenty of time to cool the turbo oil, the caution is ONLY for a really heavy pull , and an immediate stop.
Old 02-22-2019, 06:47 AM   #10
Glad you brought that up. Not a lot people...or diesel / turbo newbies know to do that.
TheWolfPaq82 is offline   Reply With Quote
