Old 03-29-2019, 01:40 PM   #1
MBS Schedule A / B Services
I am fairly curious as to what people have experienced regarding what was actually done and what it cost vs what the schedule A and B services stay as what needs to be performed. In talking with different owners, it seems what is performed often surpasses what is really needed and the fees increase accordingly. I spoke with a service person earlier and asked about the fee for a Schedule B service and was told around $450. But, I have seen comments from people on forums where the actual billings they paid often exceeded $1000. Here is what MB says a schedule A service includes:
[B][I]Mercedes-Benz Service B* is a group of car services performed at either 20,000 miles or 2 years, whichever marker comes first. Additional maintenance tasks may vary depending on your specific Mercedes-Benz model, but all models will receive the following upon coming in for Service B:
Synthetic Motor Oil Replacement
Oil Filter Replacement
All fluid level checks and corrections are dependent on factory-recommended service intervals for your vehicle’s year and model
Tire inflation check and correction
Brake component inspection
Reset maintenance counter
Cabin dust/combination filter replacement
Brake fluid exchange
Adhere to all required elements listed by model year and specific model as indicated on the corresponding service sheet for Mercedes-Benz Maintenance Systems in the USA.
SCHEDULE SERVICE
Service A vs. Service B
Service A, another group of services offered at your Mercedes-Benz service department, is performed before Service B. When you see a single wrench pop up on your main console, it’s time to come in for Service A. This feature is a part of the Mercedes-Benz Flex Schedule system that alerts you when your vehicle needs maintenance. Service B, on the other hand, is indicated with two wrench icons. Service B is a little more comprehensive than Service A, and includes a brake fluid change and cabin air filter change. For any questions relating to Service A or B, contact Mercedes-Benz of San Diego near Rancho Santa Fe! Our team is happy to help you understand the key differences.
2019 Tiffen Allegro Open Road 32SA
F53 / 24000# Chassis
2008 Jeep JKS
Ready Brute Elite / Blue Ox BP
High Desert is offline   Reply With Quote
Old 03-29-2019, 02:05 PM   #2
2012 Solera
On our 2012 MBS, every 10K miles for oil and oil filter (plus miscellaneous), fuel filter every other oil change (every 20K miles). Fuel filter adds significant dollars. Also, important fuel filter be replaced correctly- local shop “qualified for job” (but not Mercedes) caused a turbo failure on mine (improperly installed turbo compensator ring at fuel filter change).
Periodically should add brake system flush and radiator antifreeze change. Dealer seems to do the brakes regularly; has not yet done the antifreeze.
Think there is a diesel particulate filter test at about 100 K miles. Mine was tested at about 90K miles after a check engine / limp mode instance resulting in EGR valve and EGR cooler replacement. Dealer did a forced DPF regen at that point.
I think transmission fluid change should also come up - my dealer did not do a transmission fluid change; I ended up replacing the transmission at about 93K miles.
FYI - watch what is done or not done; delayed or missed maintenance can be quite costly on these Sprinters.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 03-30-2019, 07:06 AM   #3
"Also, important fuel filter be replaced correctly- local shop “qualified for job” (but not Mercedes) caused a turbo failure on mine (improperly installed turbo compensator ring at fuel filter change)."
AS the MB dealer may not have the required new ring in stock , ask to see it before a fuel filter is changed , and demand the old one after the service is done.
FFred is offline   Reply With Quote
Old 03-31-2019, 08:53 AM   #4
milkman55's Avatar
I just had the B service performed at the 2 year mark and 13k miles. The main difference between the A service and the B is the fuel filter change, but there are several other areas checked more than the A.
My MB dealer charges $199 for A service and $699 for B service. I received a $300 off coupon in the mail shortly before the two year mark, so I got the B service for $399 which I thought was a deal. Just the fuel filter part was $138 on the detail bill.
My MB dealer in Boerne, TX is exceptional and I would not go anywhere else. My service advisor did tell me the #1 cause of roadside towing was a clogged fuel filter. He recommended every 2 years or 20k miles.
2017 Isata 3 24FW
2014 Honda CR-V
milkman55 is online now   Reply With Quote
Old 03-31-2019, 02:45 PM   #5
Hi Rider's Avatar
Send a message via AIM to Hi Rider
My first "A" service cost around $300 and my first "B" service was around $800.
Hi Rider
Jack and his dog, Annie
2016 Forester 2401W MBS pulling 2006 Jeep Wrangler
2017 - 189 Days and 8,857 Miles
2018 - 193 Days and 7,024 Miles
2019 - 151 Days and 6,025 Miles
Hi Rider is offline   Reply With Quote
Old 03-31-2019, 03:26 PM   #6
mlmay12's Avatar
My 2016 Isata 3FW first "A" Service was at one year (11,000 miles). The dealer changed the Oil/Filter and replaced the Fuel Filter. Cost was $700.
After that I did the second service at 2 years (21,000 miles). I did a ton of research and did that one myself at a cost of $250. Replaced the Oil & Filter as well as the Fuel Filter (including a new turbine seal, clamps and Collector Tube). It wasn't that hard and took about 3 hours. I got a really good deal on Mobil 1 ESP 0W-30 at NAPA. A great place to get parts is online at europarts.
There is a lot of debate about how often the Fuel Filter should be changed even a difference in opinions between MB Dealers. The manual for my 2016 had a statement that said to do it at 20,000 miles which would be part of the A Service. Another place in the manual said to do it at a minimum of once per year. I followed this only because of the warranty and plan on doing it every 2 years regardless of miles from now on.
Because of the size and weight of these Vehicles I have monitored my Transmission Temperature with an Ultragauge Blue. I have found that it operates at 200 plus degrees and often as high as 225 degrees on hills and towing. Because of this I have elected to have the Transmission serviced at 25,000 miles next week and will take a good look at the fluid when I get it done, I will make a decision on the intervals after I get that done. I will get the first brake fluid change done at that time.
Mine is going in for the Takata Airbag recall that effects 2015-2017 Sprinters just like my 2005 Tundra and my 2016 Jeep Wrangler.
2016 Dynamax Isata 3 24FW
2016 Jeep Willys JK
Yellow Labs Mister Jake(RIP), Casey & Baby Chubbs
USN-RET/DOD-RET
mlmay12 is offline   Reply With Quote
Old 03-31-2019, 04:38 PM   #7
Rich.M's Avatar
Let us know how the transmission fluid looks at your mileage. I am near 30,000 and considering changing the transmission fluid.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 03-31-2019, 05:19 PM   #8
mlmay12's Avatar
Will do, scheduling for next week depending on if they have the airbag parts.
2016 Jeep Willys JK
USN-RET/DOD-RET
Old 04-01-2019, 10:14 AM   #9
Thanks to all for posting your information. It really gives a good insight as to what to expect. There also seems to be some variation, dealer to dealer on service cost.
2008 Jeep JKS
Old 04-01-2019, 12:20 PM   #10
chroniekon's Avatar
I did the schedule A myself. My maintenance indicator came on at 5200 miles and 2 1/2 years of ownership. If you normally change the oil and filter in your own rigs, the sprinter is no different. Cost was around $95 for the oil and filter. The hardest part was reseting the maintenance indicator. I never did figure it out. The dealer ended up doing it for me when I took it in for the air bag recall.
2017 Isata 3 24FW
2004 Jeep Wrangler
chroniekon is offline   Reply With Quote
service
