Old 02-07-2016, 08:26 PM   #1
khocke's Avatar
Microwave Replacement: MBS chassis
Posting here because I need to replace my dead High Pointe convection/microwave with something that will fit our Solera/Sunseeker MBS/Forester MBS coaches.
High Pointes are no longer easily found on the internet and have no interest in having my dealer to special order one - yet. I have spent hours surfing for anything close in size that has a mounting kit, or would fit the High Pointe kit. I do not have a conventional oven so require a conv/micro. If you also have the oven delete option, can you tell me what your newer coaches are coming with?
It seems the Dometic DCMC11B.F is my only mounting-kit-able choice but various internet sources quote the width (with kit) at 25-1/4" wide. I checked with Dometic customer service to confirm width but they just quote install manual dimensions for the required hole...and the product isn't even on their website. My 2400R only has 24-7/8" available for a mounting kit, although the hole itself if plenty wide for the Dometic unit.
Next stop, Campingworld with a tapemeasure, but just thought I'd throw this out there tonite for help.
2015 Sunseeker MBS 2400R
khocke is offline   Reply With Quote
Old 02-07-2016, 08:52 PM   #2
sgtlm17's Avatar
Here you you go. Cost $185 and includes trim kit.
https://burnstines.com/collections/m...s-b-ec028bsc-b
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 02-08-2016, 07:03 AM   #3
khocke's Avatar
Thanks!
Old 02-08-2016, 11:57 PM   #4
sgtlm17's Avatar
Good luck. Let us know how it works out?
Old 02-09-2016, 02:20 PM   #5
I have my convection microvave from
my Prism 24G, 100% new, never used.
Send me private massage if you are
interested
Prism 24G is offline   Reply With Quote
Old 02-09-2016, 05:02 PM   #6
Telstar's Avatar
The turntable in our over the range microwave Witt exhaust fan went out and I found out no company makes short microwaves any more. Ordered a new motor and took 15 minutes to fix. My advice is that it's Cheaper to fix one rather than replace. All the parts you may need, diagnostic info an repair videos are available at www.repairclinic.com
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2005 F-350 6.0 psd CC SRW
PullRite Super 5th
Telstar is offline   Reply With Quote
replacement
