Old 08-12-2018, 02:17 PM   #1
Ecopco's Avatar
New AGM Batteries on Coach
We have a 2015 Solera which I just installed 2 new Lifeline AGM 27ís. After charging Iím getting 14.0 on the cigarette lighter mini volt meter. The place I bought the batteries said I could discharge safely to 30% before recharging. Does anyone know what this is in volts? Iíve heard never let them go lower than 10.5 volts. Thanks in advance.
The Peterson Family
Southeast Louisiana
2015 Solera 24R
Living our dreams one day at a time!
Ecopco is offline   Reply With Quote
Old 08-13-2018, 07:31 AM   #2
A 14v reading on a just charged batt is just a surface charge and is of no concern.
Using voltage to judge the depth of discharge is very inaccurate.
To take good care of the house batts a SOC , State Of Charge meter should be installed.
This is an accurate measure like a gas gauge , that will tell the depth of charge and discharge .
Most folks will only drop to 50% discharged as it allows many more charge /discharge cycles before the batts die.
Bogart works well , there are other brands.
TriMetric Model Descriptions - Bogart Engineering
www.bogartengineering.com/products/trimetrics.html
Measures battery % full, based on amp hour measurements for accurate information on state of charge (SOC). This method is more accurate than monitors that ...
Trimetric TM‑2030‑RV Battery Monitor
$153.00
Northern Arizona Wind & Sun
FFred is offline   Reply With Quote
Old 08-13-2018, 02:08 PM   #3
Ecopco's Avatar
Thanks so much for the education. Iíll check them out.
The Peterson Family
Southeast Louisiana
2015 Solera 24R
batteries
