Old 02-20-2016, 06:10 PM   #1
Keithe's Avatar
Send a message via AIM to Keithe Send a message via MSN to Keithe Send a message via Yahoo to Keithe
New Forester MBS Owner
After a lot of procrastinating, we finally order a new Forester MBS 20401S and should be able to pick it up late March or early April. I'd like to thank everyone for all the great posts. This forum has been very helpful in making our final decision. We knew we wanted an RV built on the MBS platform but had trouble deciding which of the three models to choose from. I really liked the "W" floor plan but didn't like the reduced storage space inside and out and also didn't like the extra weight of the unit. In the end, we felt the corner bed would be a better choice for us. Time will tell.
One of the first upgrades we're plan on is installing some type of solar panels. I'm still trying to choose between roof mounted panels or portable panels. I wish Forest River offered solar as an option.
I do have one question? Do all the new Forester MBS come with a Zamp sidewall solar plug? If so, I may start with portable panels then at some point move to more permanent roof mounted panels.
Keithe is offline   Reply With Quote
Old 02-20-2016, 06:43 PM   #2
Rich.M's Avatar
May want to start puting your money and time into roof mounted panels. Renogy has resonable panels. Portable panels are known to grow legs and walk away. Consider running 6 ga wire from the roof down the fridge vent. This will give you plenty of capacity for adding panels. I am now at 400 watts, 6 ga is best to minimize dc current loss. A good reference is Jack Mayers website. Read it several times to help with your design considerations. Good luck.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 02-21-2016, 02:40 PM   #3
We too are new owners of MBS2400W and love the inside space. So far problems are few and very minor.
Several things just not covered in documentation including just what is the coax connector to the left of the coach door.
Anybody know the answer.
Thanks, Michael
gbmick is offline   Reply With Quote
Old 02-21-2016, 02:48 PM   #4
RedLdr1's Avatar
I believe that is not a coax connector but the Zamp connector for hooking up a solar power system. Open the door to the propane tank and you should see the wiring, with an inline 10Amp fuse, running to it...
Wayne and Christine
2019 Sunseeker 2500TSF On Order Due "Off Line" on May 18th
2018 Ford Focus SEL Hatchback TOAD
RedLdr1 is offline   Reply With Quote
Old 02-21-2016, 04:16 PM   #5
Thanks but the solar connector is much lower and labeled. The connector that I am thinking of is coax and is one of a row of four connectors/outlets. There are two regular 110v outlets, a 12v outlet and the mysterious coax (I have tried connecting a regular coax terminated cable and it mates)
Old 02-21-2016, 04:49 PM   #6
RedLdr1's Avatar
Now you have me wondering... The cable TV outlet is the drivers side in the rear corner. I'll take a look at ours tomorrow...
Wayne and Christine
Old 02-21-2016, 10:25 PM   #7
bob dirt's Avatar
I also have a 2016 2401WS. I have not tried that connection but believe it is the TV antenna..
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 02-21-2016, 10:40 PM   #8
MNtraveler's Avatar
Congratulations and welcome to the forum! Everything is fine here but for future reference this particular forum (MBS Sprinter) is for matters specifically unique to the MBS chassis - the engine, frame, axels, wheels, transmission and such. For more general issues you can post in the Forester forum, and for more technical matters you can post in the Electrical, Appliances, Propane, etc. tech forums. Any way you do it, you will find the greatest help here!
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 02-22-2016, 06:54 AM   #9
Mikegjax's Avatar
The connector on the drivers side is the camp cable input. The one on the passenger side should be for output to an outside TV.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 02-22-2016, 08:23 AM   #10
Class C Representative
Joshua Cavitt's Avatar
That Coax is there if you want to run a portable satellite or cant get a cable connection to the other side of the coach.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
Joshua Cavitt is offline   Reply With Quote
forester
