Old 04-28-2016, 09:31 AM   #41
Phinias's Avatar
I contacted the Mfg. of the door. They sent me two latches N/C. They must expect it to break again.
Phinias is offline   Reply With Quote
Old 04-28-2016, 10:11 AM   #42
Mikegjax's Avatar
The way those latches are built they can pop off and be snaped back on. This is not always the case. May times they are actually broken. Mine came off and on close inspection I discovered it could be reattached.
2014 Solera 24R
USN Retired
Mikegjax is offline   Reply With Quote
Old 04-28-2016, 11:54 AM   #43
Note the latch on the shower door is very important - one hard swing out into the toilet while driving it will blow up into tiny pieces as it is tempered.
My most important easy to forget checks are stabilizer feet up / shower door latched when pulling off.
2016 Sunseeker W MBS
kysunseekermbs is offline   Reply With Quote
Old 04-28-2016, 12:54 PM   #44
Originally Posted by dogpa View Post
I did the door and it was over 40 lbs and way easier to maneuver around bed.
I like the idea of removing the door...but I'm not at all clear on how to do that. Can you give us a (hopefully brief!) description of how you took the door off it's rails?
Thanks!
Dave
2015 Solera 24R
2014 Mercedes Chassis
DaveJordan is online now   Reply With Quote
Old 04-28-2016, 01:16 PM   #45
2012 Solera
Shower door latch
I had a problem with the latch on our 2012 Solera not keeping the door shut. Dealer attempted to "tilt" the door so the latch connected better - failed attempt, no improvement. The door would slam open and jump out of the lower track when driving. I fixed by adding a short piece of 1/4 inch drip tubing to the door where the latch should connect, gluin g it on with "GOOP". Has worked great since - 4 years and 60K miles, including the AlCan highway. Not sure if they have modified since our 2012 unit.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 04-28-2016, 02:13 PM   #46
psribbens
Found 2.5 gallon Blue Def at Sam's Club for $11, so two for $25 seems pretty good. I was able to get MBS Mobile 1 oil from Walmart, in a 5 gallon container, bought three for the job at about 7,000 miles--end of last 2015 traveling season--didn't want to put away for the winter with dirty oil. I know there's a lot more about these topics on this site.
Forester MBS
2015 2401S
pribbens is offline   Reply With Quote
Old 04-28-2016, 03:25 PM   #47
Rkloud9's Avatar
On our 3300 mile first trip we had no problems with the shower door or latch. All seems pretty solid to me.
Bob & Cynthia
2017 SunSeeker MBS 2400W
Rkloud9 is offline   Reply With Quote
Old 04-28-2016, 06:58 PM   #48
Mikegjax's Avatar
Check the spec. on the oil. Walmart does not normally carry MB approved 229.52 oil. Could mess with your warranty.
2014 Solera 24R
USN Retired
Old 05-03-2016, 04:26 PM   #49
MNtraveler's Avatar
Originally Posted by Rkloud9 View Post
Re: the glass shower door, note that BClemens mentioned in his post on this thread that people were choosing options like the glass shower door, even though they offered the (lighter weight) curtain... Dealers order what they think will sell, and 2400W we saw on the lot had the glass door... Little things can make a big difference in the purchase process, and the shower was a big deal for DH. I did not even know the unit could be had with a curtain, and there was no discussion of this while we were looking at it. Our dealer was only stocking SunSeeker MBS 2400W's with full body paint and glass shower doors (and probably other items we did not know were options). The only upgrades offered were the AC that included the heat pump, the diesel generator, and the side view cameras.
Bob & Cynthia
They aren't listed as options in the product brochure nor in the invoice pricing. Full body paint is listed. Side cameras are listed. If other things are options, they are not very transparent.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
Old 05-03-2016, 04:28 PM   #50
MNtraveler's Avatar
Mobil 1 is not in spec. Mobil 1 ESP is in spec but harder to find. As with most things RV, it's available on Amazon.
2016 Forester 2401R
sunseeker
