04-01-2018, 08:40 AM
#21
Atwood tank
I used a Atwood tank for 12 years with no problem of using a brass reducer to a 3/8" pet cock drain. I used a good coating of Teflon tape on the brass threads. Once every two years I would remove the brass reducer with the pet cock to flush the tank very good of any sediment.
Sid & HRH MISSY, SHIH TZU
2019 WILDCAT 28 SGX
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2023 69 DAYS
[SIGPIC][/SI[SIGPIC]
04-01-2018, 08:57 AM
#22
I have an Atwood water heater. Replaced the plastic plug with an anode I bought on Amazon.
https://www.amazon.com/Camco-11553-M...r+heater+anode
Fits fine, was able to get it in without much problem. You need to get one specific for the Atwood. Shorter than the others.
2003 Duramax
2017 Crusader 315
2016 Boston Whaler Montauk 150
Former Montana owner
Colorado Cruiser, Over the Pass and Down the Hill
04-01-2018, 09:00 AM
#23
Why would you put an Anode Rod in a water heater tank that doesn't require the rod ?
04-01-2018, 09:17 AM
#24
Well, if you wanted your water to smell like sulphur, you could put a magnesium rod inside of your aluminum water heater tank. That’s one reason.
Bruce
04-01-2018, 09:32 AM
#25
Originally Posted by nomad297
This is not true. PTFE tape does not insulate dissimilar metals when used on NPT threads — the metal treads cut right through the tape. PTFE tape does not turn a metal thread into a teflon thread.
Bruce
X2. If it did insulate the two metals, the anode wouldn't work. And I can tell you that my anode works with Teflon tape.
2011 Traverse LT, 3.6L, FWD
04-01-2018, 09:34 AM
#26
Bruce
But.....does sulphur smell like victory...in the morning ?
#27
Sacrificial anodes prevent corrosion between dissimilar metals. Tank may be aluminum, but are all the fittings? Would rather buy a 17 dollar anode than a 600 water heater. Funny how the anode shows corrosion after a years worth of use. Why is it reacting if there's no electrolysis going on? Just asking.
Anyone heard of planned obsolescence.
2003 Duramax
2017 Crusader 315
04-01-2018, 11:28 AM
#28
Tefflon tape
Well, the tefflon tape work good for me on my original Atwood on Palomino 2000 Hybride!!!!
04-01-2018, 11:42 AM
#29
Denver To Yuma In 90 Days
I've said it before and I will again:
Just because someone did something and got away with it doesn't mean it is the right (or best) thing to do!
"Free advice is worth every penny spent on it!"
04-04-2018, 11:23 AM
#30
If the anode corrodes and breaks off in the tank is it useless? and impossible to get out of the tank?
TT- 2016 Grey Wolf 21RB
TV- 2004 GMC3500 4x
04-04-2018, 11:32 AM
#31
I've never seen or heard of that happening. They have a long piece of metal in the middle of them that would prevent that.
04-04-2018, 11:50 AM
#32
It really should be attached to be of real use, although I imagine some use may be gotten from where it's touching the tank. It would be difficult to remove, but if you have some flexible steel finger tools and maybe a endoscope it would help. But it's not hurting anything and will probably eventually disappear through galvanic action.... JMHO
04-04-2018, 11:58 AM
#33
That makes sense. Ours is only corroding near the plug and it would seem that it would eventually break off.
TV- 2004 GMC3500 4x
04-04-2018, 12:02 PM
#34
I don't think so. The center rod is made of different metal - does not corrode as the sacrificial part does. See post # 31 .
04-04-2018, 12:47 PM
#35
Just as confused as you
I believe the center rod is made from mild steel, in that case a magnet should retrieve it.
Richard & Jill
