Old 03-30-2018, 01:10 PM   #1
chengdave2003's Avatar
No anode in hot water heater?
The drain plug on the hot water heater on my 2017 2400WS is plastic without an anode, and a real pain to get in and out due to interferences. I'm going to make an easier plug to get to out of brass, but was wondering why they don't use anodes anymore. Is it they don't need them or is it a cost saving deal? It will be easy enough to make the new plug anode capable, but was wondering about the electrolysis issue or not...
chengdave2003 is offline   Reply With Quote
Old 03-30-2018, 01:21 PM   #2
2012 Solera
As I understand (from posts on this forum) Suburban tanks are steel and require use of an anode; Atwood tanks are aluminum and don't require an anode. Suspect your MH has an Atwood tank.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 03-30-2018, 01:34 PM   #3
Flybob's Avatar
You have an Atwood WH Aluminum tank. See Post #3 in thread below for my solution to drain access.
Hot Water Heater Drain
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-30-2018, 02:02 PM   #4
You are both correct....it is an Atwood. Thank you for clearing that up.
This is my solution to the hard-to-get-at drain plug issue. I also broached a 3/16" hex to the end to help even more getting it started... OEM plastic vs my brass plug....
Old 03-30-2018, 04:18 PM   #5
2012 Solera
Only thought I have - any issue of electrolytic reaction between the brass and the aluminum?
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 03-30-2018, 04:52 PM   #6
I think that is a very valid question...I think I may have to remake it out of aluminum....
Old 03-30-2018, 04:55 PM   #7
D W
D W's Avatar
Exactly. There's a reason why the plug is nylon. Brass and Aluminum are not compatible metals.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
1984 CHEV SCOTTSDALE K20 2GCGK24J0EXXXXXXX (Chevrolet Legends-Class of 2019)
D W is offline   Reply With Quote
Old 03-30-2018, 05:11 PM   #8
Learn something new every day. I thought brass ws practically inert....something I was very wrong on....
Thank you.
Old 03-30-2018, 05:45 PM   #9
NH Maple Maker
russhd1997's Avatar
I did the same thing for a drain on the Atwood water heater in my old TT. It worked great with no tools required. I used to drain my WH after every camping trip.
Russ
2014 V Cross VIBE 822VRBS
2017 Silverado 1500 crew cab 4x4
russhd1997 is offline   Reply With Quote
Old 03-30-2018, 06:00 PM   #10
I like your idea and will copy it....thank you.
Old 03-31-2018, 01:27 PM   #11
DouglasReid's Avatar
That looks like an elegant solution. You are a talented guy, Dave!
2008 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 03-31-2018, 03:05 PM   #12
Elegant, but not viable. I was actually going to create a problem I thought I was going to solve.
But thank you for the compliment!
Old 03-31-2018, 04:27 PM   #13
Brass adapter
Use Tefflon tape on the tread, no more problem with brass and aluminium!
Jonol is offline   Reply With Quote
Old 03-31-2018, 04:55 PM   #14
RV Water heaters use the "plastic/nylon" plug for a good reason.The company says if something goes wrong with the pressure relief valve the "plastic" plug will blow out thereby preventing water heater or other damage. Most camping stores have new plastic plugs for sale.You will see they are hollow thru most of the plug.My Freightliner class mechanic convinced me to use the plastic ones.
Mark1 is offline   Reply With Quote
Old 03-31-2018, 05:25 PM   #15
please be careful if you do, .... aluminum on aluminum galls very easily, .... if they do, you may never get them apart, ... and if you do, more than likely they both will be destroyed
fella10 is offline   Reply With Quote
Old 03-31-2018, 09:41 PM   #16
Mark1 has a very good point. I replaced the plug with a nylon nipple and a 1/4 turn shutoff valve so I can drain the tank anytime I want without removing the plug. But it sounds like I may have eliminated one of the two safety features on the tank.
markb422 is offline   Reply With Quote
Old 03-31-2018, 10:47 PM   #17
Just as confused as you
Scrapper's Avatar
Not all RV water heaters use plastic/nylon plugs.
Atwood WH use plastic plugs because the tank is aluminum.
Steel and aluminum do not like each other. It's called galvanic reaction.
Suburban WH tanks are steel so a steel plug will do fine.
Have you ever examined what happens to Teflon tape when you remove the plug? It will not prevent the galvanic reaction between two dissimilar metals. It is used to fill in gaps between the threads to prevent leaking, just like plumbers dope/putty.
Thus, you don't need to tighten the plug so much.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 04-01-2018, 07:30 AM   #18
In water mains they use a plastic bushing, then you can put what ever fitting you want from there. As long as you can find the sizes you need.
aircommuter is offline   Reply With Quote
Old 04-01-2018, 07:58 AM   #19
On my old Jayco, I took a old wrench heated it and bent it to fit the plug better. Did a little grinding on it too for some clearance issues. Worked great for almost 10 years.
Just remember...whatever mod you do, take into account that the water heater will develop high pressure when the water is heated and whatever mod is done needs to be able to withstand that pressure.
TheWolfPaq82 is offline   Reply With Quote
Old 04-01-2018, 08:30 AM   #20
This is not true. PTFE tape does not insulate dissimilar metals when used on NPT threads ó the metal treads cut right through the tape. PTFE tape does not turn a metal thread into a teflon thread.
Bruce
anode, heater, hot water, water, water heater
