Old 02-24-2016, 07:35 PM   #1
15 -21FBRS 17-F150 2.7 e
J.Fallon's Avatar
No power to gen start panel
2008 FourWinds Siesta. No power to gen start panel also no power to coach radio and walkie talkie charger. Been through all fuses. I'm stumped. Please help.
2015 21fbrs
2014 Ford F-150 4x4 5.0
J.Fallon is offline   Reply With Quote
Old 02-24-2016, 07:42 PM   #2
J.Fallon's Avatar
It's a 24 Sa
2015 21fbrs
Old 02-24-2016, 07:51 PM   #3
VinceU's Avatar
2015 21fbrs
Have you checked the chassis fuses, normally below or on the side of the dash? Radio is my first clue, the others are small loads and may be piggy backed.
Old 02-24-2016, 07:57 PM   #4
J.Fallon's Avatar
Yes I checked all the fuses 3 times. Under dash and on side of drivers seat. All the house circuit breakers and fuses are good as well. I hooked it up to shore power to see if the 12 volt would come on but it didn't. Everything else seems to work.
2015 21fbrs
Old 02-24-2016, 07:58 PM   #5
J.Fallon's Avatar
The radio up front works
2015 21fbrs
Old 02-24-2016, 09:13 PM   #6
Do you have 12v power at your cigarette outlets in the kitchen or bedroom. Is it pssible your battery isolator switch is turned "off" keeping the 12v system offline?
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
Old 02-24-2016, 09:20 PM   #7
J.Fallon's Avatar
Thanks. I'll check in the am
2015 21fbrs
Old 02-24-2016, 09:21 PM   #8
J.Fallon's Avatar
Where is that switch?
2015 21fbrs
Old 02-24-2016, 09:22 PM   #9
J.Fallon's Avatar
The switch by the gas pedal?
2015 21fbrs
Old 02-25-2016, 08:46 AM   #10
J.Fallon's Avatar
I found it it was a 30 amp fuse behind the right side generator cover on the generator itself
2015 21fbrs
power
