09-20-2016, 08:05 PM
No signal from outside tv coaxial cable
Does anyone have this no signal problem from cable hookup? Antenna works fine. It's picking up a few channels in camp ground but cable is always no signal. Any ideas where to start? I'm thinking it may disconnect some where between outside wall and tv?
raptor
2016 Forester MBS 2401R
America is great
09-20-2016, 08:15 PM
Did you turn off the antenna booster button? Can't get cable with it on.
#1 cause of no cable signal.
09-20-2016, 09:12 PM
Yes I turned it off, but still no signal.
raptor
America is great
09-20-2016, 09:18 PM
Find the splitter by tracing it back from main tv. Make sure wires are connected and tight. You might need to pull the outside connection to check it too.
2015 F-250 FX4
09-20-2016, 09:35 PM
Thanks for all your help. I will do that as soon as it's back from warranty works.
raptor
America is great
09-21-2016, 08:01 AM
I assume you set the TV for cable and did a cable channel scan?
2014 Solera 24R
USN Retired
09-21-2016, 08:04 AM
Why not have them check and troubleshoot while there?
09-21-2016, 12:58 PM
I think I remember seeing a splitter under the sink at the wall where the outside
Cable hookup is. The splitter goes to the outside connection and back to the
Bedroom television....I think
09-21-2016, 02:15 PM
If it still is under warranty, have the shop fix it.
Ben and Doreen
Home Away From Home - 2017 PT Crusader 315RST
TV - 2016 Ram 3500 Laramie 4X4 6.7 Cummins Diesel
Never Enough Time Camping!!
09-21-2016, 02:39 PM
X2- no signal when switching from OTA to cable without performing this procedure.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
09-21-2016, 03:10 PM
Make sure you have the cable hooked to the correct input. My Windjammer has two outside coax connections: one for the cable and a separate one for satellite. And yes, it does make a difference which one you use.
09-21-2016, 03:29 PM
I had the same issue. After much tinkering I got a coax continuity tester and narrowed the problem down to the connector on the outside of the trailer. The problem was sloppy installation of the coax end at the receptical. I reworked the connection and it solved the problem.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
09-21-2016, 03:41 PM
Another possibility that hasn't been mentioned is, FR installed some TVs that didn't have cable tuner capabilities. Don't remember the make of TV for sure, but could have been Seiki.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
09-21-2016, 05:27 PM
I think my problem is similar to stormrider151. My MBS has been at dealer for over a week and don't want to add anymore issues to it. Warranties works have to be okay by FR and take a long times to approve, but I will them for some ideas when I pick it up. I'm having about 11 minor fixes like bedroom frame slide busted on one side. To me I don't think they are not to happy to do warranties works any ways.
raptor
America is great
