Old 08-15-2019, 01:00 PM   #1
No Water Pressure
2016 24 R water tank 2/3 full. Pump runs but no water or pressure. Any ideas?
John Craft
dogpa
2016 Solera 24R
dogpa is offline   Reply With Quote
Old 08-15-2019, 01:30 PM   #2
Probably your check valve in your pump is stuck. Mine does that if you had been hooked up to extreme city water pressure. You will have to take pump apart to fix, not really a hard job. Donít get water on your slide controls if they are under the pump like mine. Donít ask how I know this, those controls are expensive
lwalkplumb is offline   Reply With Quote
Old 08-15-2019, 01:36 PM   #3
Just as confused as you
Scrapper's Avatar
First things to check is a loose hose between the fw tank and pump or the screen filter mounted on the pump where the hose from the fw tank connects, it could be loose or cracked. You may also have a winterization valve in the same location, it is a 2-way valve with 3 hoses connected, the handle should be pointing towards the tank.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 08-15-2019, 01:52 PM   #4
Thanks all. I took off the hand tight filter on the incoming side. Was clean but soon as I put it back and turned on I got pressure. Thanks again.
John Craft
dogpa
2016 Solera 24R
pressure, water
