03-16-2016, 03:03 PM
#21
Originally Posted by namusmc
Thank you. It has what FR calls a Trekker cap. Although equipped with the entertainment center, storage is limited.
That entertainment center has one less cupboard than our 2016 unit, because of the additional Jensen unit (apparently) on the driver's side. In our unit, that is another full cupboard.
2016 FR Forester 2401R
Towing 2014 Honda CR-V
03-16-2016, 03:13 PM
#22
Originally Posted by LoveLife7478
Hi Josh, I have a 24W 2016 Solera. Also would like to add the Zamp solar option. Do you have the part #'s and instructions on how you installed that?
Since Zamp has been mentioned a couple of times in this thread, I wonder if people who are adding solar panels to their MBS units have actually weighed their units? I just weighed ours and we will be lucky to meet the GVWR once we fully provision it with clothing, hiking gear, food, beverages, passengers, pet, and 75' of additional 30A wire we need for Canadian campgrounds. The weight includes all fuel and LPG, but no water or anything in the holding tanks. Folks may want to hit a nearby CATS scale to see where you are at. Based on our result, I would say the empty vehicle weight was probably more than advertised and the cargo carrying capacity (CCC) was less than advertised. Our CCC is supposed to be 1178. I sincerely doubt we have already put 650# of gear in there but we only have 530 left to go. I now wish I had weighed it empty, and may do that next time it is empty!
03-16-2016, 03:19 PM
#23
Originally Posted by Farkasb
Hey Josh, I heard that you're starting to add back front gutter spouts. Is that true? And if so is it possible to order some that match ordered paint scheme?
Our 2016 includes front and rear gutter spouts on both sides and they are painted to match as I recall. Very good features. The only downsides I see are the front driver's side drains out at the driver's door - look out when exiting (I suppose the passenger side does the same but haven't noticed it yet) - and the rear passenger's side essentially drains the water out and down the rear strut of the awning mechanism. Apart from dirt and staining, I tend to believe this will cause a problem down the road, possibly rusting or paint deterioration. I may try to figure out how to add a 1-2" extension lip onto that drain.
04-14-2016, 09:14 AM
#24
Our salesman said the new ones have a larger propane tank too.
Derrick
04-16-2016, 01:36 PM
#25
I'd double check that as the new brochure still lists the 9.8 gallon tank. There has been a lot of discussion here about needing a bigger tank for boon docking. But FR has consistently said they are limited by weight constraints in the MBS. The only MBS variant that I know has a larger tank is the Isata 3. I think the Coachman's also have a larger tank but I'm not positive on that one...
Wayne
2024 Sunseeker 2150SLEF / Ford E-350
04-16-2016, 01:53 PM
#26
I hope it has the larger tank (16.8gal). It was one reason we ordered it. The small tank was a major hang up for us since most of our camping is boon docking.
04-16-2016, 02:45 PM
#27
Hey Josh! LP Tank Size Question...
Let's ask the man who will know! Josh is a FR Class C factory rep...
Josh,
Are they putting a bigger LP tank in the MBS now? And how about the other Foresters / Sunseekers?
Wayne
07-14-2016, 06:56 AM
#28
Josh,
Is this a yes or no on the larger LP tank?
07-14-2016, 08:11 AM
#29
We got ours about a month ago and it does have a larger LP tank. I believe it is 16.8Gal.
07-14-2016, 08:37 AM
#30
Every Forester and Sunseeker model in the latest brochures is 9.8. 16.8 would be really heavy!
former 2017 Forest River Sunseeker 2250SLE owner - replaced by a Pleasure-Way Tofino and then an Ontour 2.0
07-14-2016, 08:55 AM
#31
the tank is 16.8gal but I think the actual LP capacity is like 13.3. I will try to remember to take a pic of it when I get home. They also did away with the metal awning cover.
07-18-2016, 09:47 AM
#32
Class C Representative
16.8 Gallons of propane is what it will truly hold.
We've made some changes to accommodate the weight of the new 16.8 gallon propane tank.
PLEASE do not send questions via Profile comments or Private Message, my inbox fills up too quickly. Post questions in the forum as a new thread so that other users can benefit from the answers. Use Private Messages for sensitive information only (VIN, Contact info or things you do not want the public to see).
07-19-2016, 06:54 AM
#33
here is a pic of the tank label. Sorry for the confusion in my earlier post. Not sure where I came up with those numbers.
07-19-2016, 08:45 AM
#34
This is the same label mine has. 19.3
07-19-2016, 12:21 PM
#35
According to Onan RV QG3600 LP - 3.6kW RV Generator (LP)
burns .6 Gal/Hr @ 1/2 Load
So that would mean about 16.6 gal / .6 gal/hr = 27 hours at 1/2 load
How many watts does the a/c pull?
03-28-2017, 10:51 PM
#36
Ceiling
I'm curious as to why the soft ceiling went away? Considering all the competition has it won't that be counter productive and negatively affect curb appeal?
