Old 10-02-2016, 09:53 PM   #11
raptor's Avatar
Blue hose and nozzle were clear of any debris, but still no water come out. I don't really need to use it just worry when winterizing the rig. You know what happen to it if I can't get all water from that section out? One more last thing I can do is to replace the quick connect. I hope it only screwed to the end of that PVC pipe.
raptor
2016 Forester MBS 2401R
America is great
raptor is offline   Reply With Quote
Old 10-02-2016, 10:55 PM   #12
If you have a blue spiral hose and one end look's like an air hose fitting, stick a phillips screw driver into the quick connect and give it a tap with a hammer. The valve is stuck inside. If they are not used much they seize up.
Bigfeet is online now   Reply With Quote
Old 10-02-2016, 11:31 PM   #13
raptor's Avatar
Thanks I'll try in the morning.
raptor
America is great
Old 10-07-2016, 09:31 PM   #14
That is exactly what happened with mine. I checked it at the purchase inspection but never used it again till months later, when I couldn't get the fitting engaged. I happened to be at the factory for a tour and they agreed to look at this and the poor radio reception. The tech there couldn't get the fitting in either and said just have your dealer put a new one in. The also installed a new antenna, which made little difference in reception. At the dealer the tech took a screwdriver and a hammer, whacked it once and voila, engagement! There is a little ball that seems to get corroded in place. You do need to drain this or you'll crack the pex or the fitting in winter. Then you'll get to replace the fitting.
Eric Jackson
Ottawa Ontario Canada
2015 Solera 24R
backdoctor is offline   Reply With Quote
water
